I have a recently lacquered chair that was waxed and would like to go back and finish it better. I believe I didn’t get the lacquer sprayed on too well and would like advice on the best means of removing the wax before correcting my mistakes. I have seen a product called wax wash remover but would like to know if mineral spirits might work as well. Any tips welcome.. NB The base material is wenge.
Edited 6/24/2006 11:05 pm ET by NumberNine
Mineral spirits are (is?) the traditional way to remove wax. Should work just fine.
excellent, I'll give it a go, thank you
Ms Forest is exactly right--I'd add one thing--use lots of rags or papertowels so you are removing, not just smearing the wax around.
Amen, amen. I own stock in Viva paper towels, so buy those, eh?! ROFL.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Mineral spirits and the sanding to the raw wood should be enough.
