I have seen references to metal wear plates on the soles of wooden planes. I’d like to know how they are fastened?
I build them in. Keyed with a little filing and then epoxy.
30"jointer
You can do what Derek has done, or you can pin them in with brass pins (made from brazing rod) set at an angle, or you can use brass screws with heads either ground off or partially counter-sunk and ground flush.
I don't like using epoxy alone for this because it is not good with brass, but is better if used with pins.
Hi Metod
That is excellent.
I have two or three wooden planes with metal plates attached. One appears to be a repair and encompasses all the sole ahead of the blade. The other comprises the entire sole and may have been installed at the time the plane was manufacturerd, but I'm not sure. Both are held in place with straight slot flush head wood screws. One might think these would pose a problem, marrr the work etc, but they don't. These are both fairly old planes and their bodies' are none the worse for wears (so to speak).
Adam
Metod,
That is a very clever idea. I may have to steal that sometime....with your permission of course.
-Chuck
