Good Day Everybody,
for an upcoming project I would like to use wedged through tenons which should be about 3/4″ thick. However, I would like to use rounded ends (not squaring the router-cut mortises) to complement the design. My questions are:
1)how do I cut the angled mortise walls (fancy router jig or freehand with a gouge, sandpaper or rasp)to achieve the “wedge-effect”?
2)I understand that typically wedges should be inserted about 1/8″ or so from the end of the tenon. with a 3/8″ radius of the rounded tenon end that becomes a bit of an issue. I suppose I could angle the cut for the wedge, but that does not seem like a good idea – strength-wise. Inserting the wedge in the round part of the tenon might be an option, but I don’t think would look good. Besides adjusting the mortise would be tough…
Any suggestions are appreciated.
many thanks,
Lars
As for the angling of the mortise, no doubt you could make a jig for the base of your router. If it were me, I'd probably just use a gouge.
As far as insertion fo the wedges, there is no rule that has to be 1/8th from the end. If you really thought that the tenon wouldn't flex enough at 3/8th, you could always cut a notch at the base to effectively make the hinging area thinner - the mechanical strength of the joint would not be affected.
Here's a wedged tenon I made fairly recently. It's about 3" long, to give you a sense of scale. And I definitely allowed much more than 1/8th at the ends. I had no problem drivng the ebony wedges into this cherry.
