I started a new project. Some built-in cabinets and bookcases. It will take about 7 sheets of 3/4 ply, and several more of 1/4.
I usually break down sheets in the garage, slightly oversize, with a circular saw. Then I wrangle them through the house, into the cellar, and trim them to final dimension on the table saw.
This project has a bunch of parts with really odd angles, too.
I said screw it, and bought a track saw. I went with the Festool corded saw.
It’s magical. The edges are perfect, splitter free, and I can cut directly to final dimension, without trimming on the table saw. Long cuts at odd angles are easy as pie — lots easier than on the table saw. Dust collection is nearly perfect, too. Cuts with the hose connected were a little awkward at first, but the trade-off is worth it.
I’m getting work done in a fraction of the time, and as near perfect as it can be. I should have done this a long time ago.
Tracksaws are definitely useful, but they still rely heavily on the human element for accuracy. My grandfather used to say anytime you measure you create a chance for inaccuracies. With that in mind I still will rip to final size on my table saw if at all possible.
Fences, jigs, guides, anything that takes the measuring tape and human eye out of the equation will always be more accurate.
Good to hear. Consider installing an overhead track system with swivel hooks to keep cords and hoses out of the way and off the stock.
Figuring out how to keep the vacuum hose out of the way takes some work. I thought about getting the cordless saw, but the cord really isn't an issue, because of the vacuum hose.
I think I'm developing an allergy to whatever is in this plywood. The small bits I've had to trim on the chopsaw in the basement have made my head fill up and nose run instantly. But it hasn't happened once in considerably more cutting on the track saw. The dust collection is really top notch.
Would you get rid of your table saw now? Id love to gain the space and often wonder if this is the way to go. I dont often work with sheet goods, but do occasionally. Only time I use machines for joinery is to hog....so I'd love to hear your opinion.
No, I still wouldn't get rid of my table saw. And if the table saw was in my garage, and I could take sheet goods directly from the truck to the saw, I would just do that.
Now that the cabinet bodies are done, I need to start making face frames and doors. I'm sure there is a way to rip those narrow parts on a track saw, but it's easier and more accurate to do all that work on a table saw.
But in the future, for sheet goods, I don't expect I'll use anything else.
Fair enough.
