I’m wondering what blade to use for a finger joint. I need to get a flat bottom and the ATB blades obviosly don’t give that. I realize why the standard blades are not flat bottomed but whereever I read about finger joints they never talk about the blade. I just don’t see any flat toothed blades at the stores. Thanks. Michael
Some rip blades, such as the Freud LM72, have a flat tooth design that should work for finger joints. There's a note on this page where the author mentions using a Ridge Carbide combination blade that provides flat-bottom cuts, so he doesn't have to swap out to a rip blade for box joints (see the 4th paragraph).
Thank you very much , I'll look for one of these.
A flat gring rip blade will work or we just came out with a two blade set specifically for this. Item is SBOX8 and it has tip angles optimized for end cuts. The two blades will stack face to face to make 1/4" slots or back to back for 3/8" slots. HTH
Freud America, Inc.
Ooooo, I'd forgotten about the Freud box-joint cutter set. Cool thing and the few reports I've seen have been super-positive. Here's a link. Click on the "larger image and other views" link and you'll see (sorta) how it works. Price looks to be around $56.
The Freud set looks good; you can also get a Forrest blade ground to make flat bottom cuts, but then your finger joints will only be 1/8".
Siskiyou
I bought and have used the Freud SBOX8 and it works great and very easy to use! Just as advertised easy to set up, just make your own basic tablesaw jig , one setup and every joint is cut the same, I would highly recommend this blade, every joint I have cut so far has been excellent.
R13
I too have used the Freud Box Joint blades, Actually I work in a Woodworking Outlet Store and gave a DEMO yesterday. As you know, while making Boxes you are cutting end grain. I was very impressed with how well the blades cut. I also used the MIGHTY JIG Which We sell. OK I work at http://WWW.EAGLEAMERICA.COM I took less than ten minutes to knock out the 8 ends of the box, probably should have taken a little more time and clamped each pass and you can actually do two ends at a time, which I did on another box. If your a fan of double sided tape you can do all four ends at once ( just remember to offset two of the sides the width of the joint tongue.
I've wondered about this myself and I was surprised that Freud came out with their product. I have not yet bought a stacked dado set, but I assumed the outer blades on most/all were flat grind. Does anyone use a dado setup for their finger joints or splines, etc where you don't want the little "ears" in the bottom of the cut (that come from an ATB)?
