I am trying to find out if there is sucha thing that encases wood beams that are two by fours in a bedroom where the wall was torn down to make it bigger
drywall, spackle, and paint maybe?
If the room is drywalled I would put corner beading on it, mud it, sand it and paint it.
I had a friend who tore down a wall to make a larger room from two smaller ones. He put up a distressed beam that he made out of a 6x8 timber. This hid the sill plate he had exposed. He nicked it up with a hammer and hatchet, sanded it, stained it and it looked great. He made mortises in the studs and tenons on the end of the beam. it was a bit of tight squeeze so he had some patching to do on the wall.
You could do a faux or fake beam by wrapping it with three boards. Not sure what the layout is, so I can't target my comment.
Ken
"Do as you would be done by." C.S. Lewis
They make hollow foam 'beams' for just just that purpose, They are light weight and finished to look like barn beam It is extruded in a U channel shape that will 'cap' the existing studding Easy to saw and to cut with a knife. I wouldn't use my email address as you've done. Instead use a simple pskyeash
Edited 1/3/2007 10:53 am ET by Steinmetz
might want to post at breaktime (finehomebuilding.com) too.
