I have just finished building a chest of drawers. The outer case and drawers are finished with tung oil. I would like to know how to finish the inside of the drawers, if at all, such that I don’t have a lingering smell for the next few years every time the drawers are opened.
crp
nothing, or only shellac if you must
CRP,
Shellac for a few; if you're doing several, sprayed lacquer.
Good luck,
Paul
crp , I'm with jazzdogg on using lacquer .The smell generally flashes off within a week or so . Little wear and tear occur inside a drawer on a case such as a dresser.I have several chests that I made over 25 years ago and the insides of the drawers look like the day I lacquered them.
good luck dusty
Crossgrain Red Cedar raised panels for bottoms and no finish for me, thanks. A tad of parafin wax on the slides, tho.
http://pic3.picturetrail.com/VOL12/1104763/2594265/36624721.jpg
Bob ,
True for a reproduction piece , your way would be appropriate . For pieces that are sold to customers that are not repros, I could never get away with that. Gosh forbid if something ever were to spill into or otherwise , the drawer would be vulnerable to stains and soils , not to mention the fact that some garments may catch on a splintery surface. Really it depends on the application .Aromatic cedar IMHO should never be sealed , it would defeat the purpose , I would agree with that .
No problem.....shellac then for me.
I've sold a few things over the decades and I honestly don't remember ever discussing it with a client. But I didn't build to order, either.
Edited 11/14/2003 8:38:03 PM ET by Bob
Traditionly, the inside of carcases and the part of drawers that are inside the carcase were not finished. So, that is a perfectly acceptable option. Drawer insides were lined with paper.
If you want to finish the inside of a carcase or drawer, do not use an oil based product. Oil based finishes off-gas almost forever and the odor permeates cloth and clothing. Use only waterborne or shellac. Sometimes lacquer is used but some lacquers have a lingering odor.
I pretty much use ash or birch for my drawers.
I often times use a waterbased poly on the insides. It makes the drawers insides silky smooth, though I agree that bare wood is definitely ok too.
I also have used oil based wood conditioner to get some color/character out of the wood, let it dry for 24 -48 hours, 0000 steel wool, and buff. I never had a lingering smell with that option too.
Does your tung oil smell? Might as well use it up. It's a lot easier to wipe on than to spray a finished piece.
It seems to me that any oil or varnish finish has lingering order issues. Thats why I use Shellac.
Mix up a 4 lb cut, and the next day when it is dissolved flood the s h i t out of each drawer, wait about 15 minutes and wipe it down with an alcohol soaked rag. Two applications should do.
Boris
