I am planning to build our own kitchen cabinets. The kitchen will be heavily used with fair amount of grease and steam deposited on the cabinets even with strong ventilation systems installed.
I intend to have painted cabinets.
The question I have is – What is the most suitable finish to use in this situation?
Paint is the finish; semi-gloss or gloss cleans easier. Gloss enamels are too shiny for my taste. If the cabs are stained then a lacquer or a polyurethane varnish would be suitable.
*The eggshell finish is a pleasing surface to me--agree about gloss. Eggshell is just a little different from semi.
*Thanks for your advice. Is there special paint for kitchen cabinets? If we use cleansing agents, would the paint stand up? What about the surfaces that's close to the stove? Should they be specially treated?Thank you.
*Unfortunately, the oil paints usually stand up better to such cleaning than the latex paints. Consider looking at Consumer Reports - they regularly evaluate paints.
*I had my cabinets painte d professionally several years ago. They used a primer caled XIM (and no, it is not BIN) plus several coats of eggshell OIL based paint put on with a fine fine roller. It is a wonderful washable finish that has held up--a few nicks that I need to repair. The surface is extremely attractive and I have a LOT of it.
*If you have spray equipment and a booth, the absolutely best finish for kitchen cabinets would be a pigmented conversion varnish; following that, catalyzed lacquer.If you're not set up to spray finishes, a good-quality oil-based paint will serve you well. You can prolong the refinishing date by topcoating the paint with clear polyurethane, but doing so will change the color slightly by adding an amber tone to it.For more on this subject, see Chris Minick's "Kitchen cabinet finishes are different" in FWW issue # 139, pp. 141-142.
