What kind of wood is this? Cherry plywood?
Unlikely to be plywood at that scale and grain orientation. Looks like a rollcut veneer applied to a substrate..possibly plywood I suppose which makes the whole thing plywood in the end.
It has a cherry feel to it, but could be many things after staining etc.
Looks like plastic laminate to me.
I'd bet on plastic also. But it's a piece of plastic with a picture of cherry on it.
I understand why places like fast food restaurants use plastic laminate. Its the perfect material for that setting. But when it is designed, they take a picture of a tabletop made of real boards.
What I don't understand is, why do they take a picture of mediocre, or even crappy boards? Why take a picture of a top glued up from a bunch of 2, 3, and 4 inch wide lumber? Why not make a top with a gorgeous 20 inch wide piece of curly cherry, or crotch mahogany, and then take a picture of that?
Its cherry. The question is whether it is plywood or laminate.
A quick look see underneath will answer that.
Looks like cherry to me but do not know if it is wood, could be a plastic laminate.
The lights reflecting on the top surface certainly make it look like plastic laminate.
I wonder why the grain patterns don't align where the table top sections meet? If this was a custom made wood top you'd think the builders would have made sure the grain pattern was continuous.
I’m pretty sure it is plastic laminate. If you look carefully you can see the exact same cathedral pattern (spun 180 degrees) repeated on the next section of the table top.
Wow, good catch JEarch! I looked for a repeating pattern but never found it.
