I need to try and match the end table in this picture for a desk I’m making. I think its red oak with dark walnut stain. Give me your best guess please.
That's a good guess. Red oak almost certainly. There are probably a couple dozen stains in that color family with a wide variety of names. Dark walnut is as good a place as any to start. It depends on how exact you want the match to be.
Rather than guess, I go to any hardware / paint store and try to match up the photo with their stain display. They usually have red oak and maple samples as a minimum. Rockler and Woodcraft might have more of a selection.
You need a close up.
I've had to make pieces to match old furniture on several occasions. I find it rare that a stain out of the can does the trick. I try and buy two colors on either side of the one I'm matching and blend. Sometimes I get lucky and they're indistinguishable, sometimes "close enough." Alternatively, you can buy tints and mix your own, but I've not gone that route.
Being colorblind, I often find it difficult to differentiate between red and white oak since my eyes are insensitive to red. To make sure I have white oak, I sand any oxidation off the surface which imparts a brown (red) hue. Usually the inside of the piece has an unfinished area you can do this. After sanding, use a strong flashlight to look for any pinkish hue that will rule out white oak. Then you'll have your specie nailed to start off on the right foot.
Thanks for the help
A finish, poly or otherwise can change the color more or less, so dont just go by the stain itself.
