In FWW issue #193, page 43 they have an article about router stile and rail bits from Amana and Freud that feature stackable cutters for veneered plywood that is not an actual 1/4″. I cannot for the life of me find the model numbers. Can anyone out there help me? FYI–it is NOT the 99-261 set. thanks in advance.
There are more old drunkards than old doctors. Ben Franklin
Freud has an adjustable tongue and groove set which will do for shaker style doors.
http://www.amazon.com/gp/product/B00006XMTT
Thanks, but that's not the set in the article. I wonder if they introduced then discontinued them. I may end up having to try to get in touch with the author of the article.There are more old drunkards than old doctors. Ben Franklin
The part number for the Amana adjustable bit set is 55346. The number can be seen on the bit at the bottom of page 43.
Life is what happens to you when you're making other plans.
When your ship comes in... make sure you are not at the airport.
Hi,
Great!!! thank you very much.
BleuThere are more old drunkards than old doctors. Ben Franklin
