Hi all. I’ve got a spare room where I want to use one end as a wardrobe, but noone will ever see the inside other than me, so what I thought was to put up a frame and hang doors on the outside. Question is, what size stock should I use for the frame? It’s all going to be screwed together so will in itself form one solid unit, and I’m going to screw down through the lower studs into the floorboards, so I think it will be sturdy in itself. Can I get away with using 3/4″ x 2″ or would I need to go up a bit?
Thanks in advance.
Roger
I believe you will be happiest with a standard 2 X 4 framing. You don't want that door to sag.
Bruce S.
Thanks Bruce.
