I have a couple logs that I would like to cut to appropropriate lengths for future turning.
Is there a “standard” or recommended length to cut the various sections of the log? Yes, I can guess one reply could be, “It depends on what you are going to make.” I understand that. However, I don’t know what all I will make. So, I am simply looking for some typical recommendations.
Would a standard be the length should equal the diameter of the log? Or are there better standards.
Any suggestions will be appreciated.
PS – Note Added: I need to clarify — I mean turning bowls, not spindles.
Alan – planesaw
Edited 3/21/2009 9:31 pm ET by Planesaw
I would cut your log maybe 4 inches more than the diameter. That wold give you the full diameter to use and a couple of inches on each end to sacrifice to checking (drying cracks).
Thanks. Hope to minimize the checking, but will follow your advice.
Alan - planesaw
http://www.preservation-solutions.com/product.php?product_id=1003&category_id=1000&source=GreenWood&keyword=Pentacryl
Check out Pentacryl for preserving the wood. PEG is the old way. Pentacryl is a much improved and superior product.
RickL,
Will do. Thanks.
Alan - planesaw
Leave them full lenth and cut of what you need as you need it.
Are you making legs for tables and chairs? How long is your lathe? Are you making bowls?
I'll never forget splitting a hickory log 24" by 3' long. I pounded the wedge off and on for a few days. Once the wedge popped out of the log and sat on the ground three feet away,and was steaming from friction. Finally the log began to make groning sounds and split. I made several table lamps from it, the hard part was boring the holes for the wires.
Tom
Edited 5/13/2009 5:39 pm ET by TomHigby
Tom,
Probably more like bowls.
Alan
What diamiter are the logs you have?
probably about 15 inches by 8 ft.
Cut up the log into 18" lengths and seal up the ends with Anchor seal right away.
Thanks Tony.
