Hi,
A friend of mine returned from India today and brought me back a bag of what I thought was going to be shellac. It turned out to be seedlac though, I believe. Does anyone know what I can do with this? Is there a way to process this into shellac using “home” methods.
Seedlac is just unrefined shellac. After the branches with the Lac bugs are broken off the trees, the sticklac is crushed, sieved, and washed. What's left is the raw shellac; seedlac.
To use seedlac, just dissolve it in alcohol like any other shellac using the proportions needed to get the cut you want. Once dissolved, filter the shellac through cheese cloth or a coffee filter to remove the residue. If you want to remove the wax, let the dissolved shellac sit in a jar for about a week and then decant the clear liquid from the top of the jar.
Paul
Seedlac over walnut is gorgeous. You do have to go through the above drill. It gives a lovely amber tint- very period. Try it on some scrap. If you use linseed oil first it is even more impressive.
Frank
Can't you plant it in your garden and grow your own shellac trees?
Sorry - couldn't resist the pun.
Plant it....... ha-ha. Very punny. Actually, I love it!
