I bought a new Hollow chisel mortiser and it is covered in grease. I was thinking acetone is this ok?
thanks
thanks
Mineral spirits has worked for me.
Bill Arnold - Custom Woodcrafting
Mensa Member
Click Here if you're interested in a good, inexpensive website host.
I've always used kerosene,it does the job quickly.
Kerosene is generally recommend for removing the cosmoline. It quickly cuts the grease and leaves a residual light film of oil that retards future rusting. Mineral spirits is a one step more refined petroleum product that will work fine too. It will not leave the oil residue.
The two new tools I've gotten with cosmoline on them had specific instructions not to use acetone. Being female, I followed the instructions. Used kerosene. Used a plastic scraper to get alot of it off, then paper towels and kerosene.
I've used WD-40 in the past without problem. There is no issue with rusting where I live so WD-40 may not always be a good solution.
I've never heard that before, will WD-40 promote rust?
Minerial spirits or naptha works good. Be careful with the oiley rags they start fires.
Have a nice day Lee
For my TS I used WD-40 and a plastic scraper. Worked ok...
Why not a match :-)M.
For my TS I used WD-40 and a plastic scraper.... Ya live down south?
Acetone will take the paint right off of whatever you clean, in most cases.
Kerosene works well. It is (relatively) inexpensive, does a good job and has a low vapor pressure, so it is less volatile; it is also less likely to spontaneously combust (plus you can use it as jet fuel)...
Glaucon
First, use dry papertowels to remove as much as as you can. I use denatured alcohol next because it won't hurt the 'lectrics if you get a little messy with it. Pour it on the tool and wipe with clean papertowels. Voila.
Whatever you use, I'd use something that EVAPORATES. You can go back and wax the cast iron parts or spray with TopCote to prevent rust.
Mineral spirits are good, takes a while to evaporate though...Kerosine works well too....
Being a shooter, I have found that using Hoppe's#9, which I use to remove the cosmo from a new firearm, works well. Figure it is safe for an expensive firearm, why not a tool. HTH
acetone OVERKILL I think..
