I am very new to this hobby, but enjoy challenges. I think I have a bigger challenge than I expected with this project. I am working on the Federal Style folding card table featured in Fine Woodworkng last year.
Because I am new at this, I literaly go by the book. I have not been able to find information on the following:
The decorative details of the table require very narrow stringing of veneer, two strips of a 1/16th inch width each. What methods and tools should I use to scribe or gouge the grooves to inlay the stringing? I already have the strings.
Thanks.
The tool you need for this job is a scratch stock. Although you can buy this tool there is no reason to, for you can make it in about ten minutes. I have sketched a typical example for your needs and attached it a a PDF file.
The blade can be made from old hack saw or band saw blade although it has to be heavy (1/16"). I generally use 01 flat ground stock which you can buy from tool supply and industrial hardware sources. McMaster Carr has it (http://www.mcmaster.com). I buy 1/2" wide by 1/16" thick stock and it comes in either 18 or 26 inch lengths. You do not need to harden it.
You simply grind (or file with metal files) the blade to the desired shape and leave the burr on it. After adjusting the blade for the proper offset from the edge you are ready to go. In use you tip the blade forward in the direction of travel and make repeated passes. (Just as you would with a card scraper) Cross grain is more difficult than with the grain and corners are the most difficult. You have to pull out of the corners tipping in the direction of travel. You can use either edge of the blade. Remember you only have to cut down 1/28 on an inch. Once you glue the bands in place sanding will wash away most sins. Practice on a scrap of wood the first time but this is really very easy and a lot of fun.
With best regards,
Ernie Conover
