I am maknig a couple of book shelfs for a friend that doesnt have much money but loves the look of cherry. I know there are some types of wood that can be finished to resemble cherry but I am not sure what they are or which ones are the best, cheapest, or easiest to work with. I was hoping you could help me out. The bookshelfs are simple construction with solid face frames and plywood shelfs and sides. Thanks for the help.
maple to cherry no problem!
Although staining is not one of my strong points, I have seen birch stained to look like cherry - it looks very good when done by someone more talented than I am.
Good luck,
Richard Baker
I second the maple to cherry. I have built bookcases birch ply sides/ maple face frames. put a little minwax cherry stain on it an presto.... or at least close enough, IMHO
Poplar, when stained, can look like cherry. I would suggest Old Masters Cherry Penetrating stain #40304.
PlaneWood
I've never had much luck staining poplar, particularly when it's real "green" (in color, not freshly cut). But with a coat of orange shellac and then some tinted polyurethane over the shellac it comes out nice.
Work it out on scrap first.
David
Alder is called the "poor man's cherry". I've built pieces out of alder and placed them next to cherry furniture and haven't found anyone - including some professional custom furniture builders - who can tell the difference. Alder costs 1/2 or less than cherry - recently bought a couple hundred feet of cabinet grade for $1.30 BF and select for $3.00. The drawback is that it is fairly soft. I don't use it in areas that will see physical abuse.
Alder.
DR
JONAS ,
I also would use Alder if we needed to keep the price down , I had the local paint store take some Old Masters Cherry stain and mix some yellow colorant or tinting compound into it to kill the orangy effects of the Alder and wa lah !
good luck dusty
