I keep seeing these pop up on E-Bay and even saw one at the State Suplus. Could someone tell me what these do? Even when I saw one up close it didn’t seem obvious what it was used for. Any help would be great.
John
John
It was a jointer that used a unique rotary cutterhead. I believe they were discontinued in the 60's. You could joint real short pieces.
John
http://www.maxkrimmel.com/Woodturning/SquarePlan/SquarePlan.html
The new spiral heads will do a nice job on figured woods.
byrdtool.com makes retrofit heads and Grizzly and Woodworkers Supply have machines and heads.
I have good luck with figured wood by using sharp cutters and slow feeds. See also back bevels. The nice thing about the uniplane would be how Max Krimmel in the above link uses it for his segmented bowls with the grain running in all manner of direction. Replacement cutters for the uniplane would have to be custom made. As in all woodworking many people will come up with many solutions to the same problem.
Thanks for the heads up Rick. Maybe if I can get a good deal on a Uniplane I will try it out.
