What’s right nailer for PT pine shingle?
I’ve got a pallet full of Lifepine shingles waiting to go up on roof of a large shed. The instructions recommend pneumatically nailed ring-shank nails 2 1/2″ to 3 inches. I’m going to use stainless (shingles are supposed to last 50 years). What is the correct nailer to drive these? should I use a framing nailer, or do I look to get a siding nailer? Can you recommend model. I’m only semi-pro, so I probably will buy on E-bay, or get a lower-end nailer that less than $300 if possible, all I have right now is finish nailer which maxes out at 2 1/2.
Contractor neighbor (who has never used PT shingles yet) thought I should ignore instructions and attach them using staples, just like he does with cedar.
Dave head over to Breaktime with this question for more exposure.
Hitatchie siding nailer is the gun to go with here, but, could you use a framing nailer after yur done with yur roof??? Some thing to consider..
Staples won't last any where's as long as nails...
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming....
WOW!!! What a Ride!
Thanks for the tip on Breaktime. It looks like I'm the guinnea pig on this, no experience over there.
So does your response mean that I could shoot thinner ring-shank nails with a framing nailer? (The pine shingles I've got are pretty thick, so they can probably take a decent sized nail.) I work as a homehandeyman, and I'm constantly building stuff in general, so a heavier duty nailer *will* get used in the future, and the more multi-purpose it is the better. I sorta like driving framing nails by hand, so I'm not sure I want that. Its not unlikely that I would be asked to do a deck in the next year, and I can see this nailer being used for stainless for the decking.
I still in a quandry about this. It looks like all of the siding nailers I've seen reviewed will only shoot 2 1/2" nails max. I may regret getting these thick shingles, in some locations I know I'm going to be shooting 3" nails! BTW, I just found a good review of siding nailers: http://www.toolsofthetrade.net/articles/showarticle.asp?articleID=1615&partID=2, note that this is part 2, part 1 in my browser was invisible until I typed Ctrl/A to select all of the text, the text was the same color as the background.
get a MAX coil nailer..ya wont need 3'' nails..2.5 is plenty
got mine at tools-plus.com best price around, for the best gun and the nails I got from MAX.
Spheramid Enterprises Architectural Woodworks
Repairs, Remodeling, Restorations.
I'm a whimp.. I've forgotten what's it like to drive by hand.....
While yur over in BT try the search function for nailers and siding, these topics have been discussed more than once...
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming.... WOW!!! What a Ride!
The Hitachi #75AG will handle 3" nails...combination framing and siding nailer, so it should also handle shorter stuff as well. I have their #65AH siding nailer and it is great, but it will only handle 2 1/2: maximum.
Not cheap, though.
Well, I ended up getting a Hitachi NV83A2. A friend needed a contruction nailer for a short period, and agreed to pay for part of it.
I probably would have bought a different nailer, if it was just for myself, but this works just fine and it handles bigger nails than most siding nailers if I ever want to do that too.
I've finished most of the roof at this point, and this nailer shoots 2" ring stainless shank nails just fine. I had to turn down the pressure to 60 lbs/in, and the depth adjust is set to lightest. No jams, and I've shot 4 or 5 coils.
BTW, I think the difference between the 83A and 83A2 may be that the later has a depth of shoot adjustment knob, whereas the previous model may have required you use a allen wrench.
Good luck!
