Hi All ,
It looks like a mini vice / clamp , but for what use and how was it used ???
dusty
Have not a clue but I love to speculate and say that it is a saw vise for sharpening hand saws.
Troy
Hi Troy , Yeah , maybe . There is a dovetail like keyway in each half but it is stopped and does not go thru the other side .Maybe they clamped it in a vise ?
dusty
I agree with you Troy.
Bob Salamy, Tupper Lake, NY
I believe it is the jaw to a leather stitching pony. That is a device that holds pieves of leather tightly together while you hand sticth it. It is usually attached to a riser that comes off a seat.
You are Correct !
Glad to hear we are all so smart:) After thinking about it I wonder if I have seen something like this in one of the wood working mags.Troy
Troy, you are dead on. I made one of those 40+ years ago from a plan that looked much like that. We didn't have the bucks to buy the "new" fancy carbide blades then so we resharpened the steel blades . Paddy
ps. but that's a REALLY old one. pfh
It looks just like a harness makers stitching pony.
When I did leather work, I had one just like the one in the picture except that at the bottom there was a cross brace to put under my legs to hold the piece firm in my lap while I stitched it.
Mike D
Could be from a stitching pony but it also looks like the clamp for a carving horse (not the kind that holds the piece when you sit down). The dovetails are used to mount it to the extension of the seat.
Edited 1/21/2007 1:22 pm by highfigh
Hiya highfigh ,
Yeah , on the dovetail for the mounting , that makes sense . Several of the other posters spoke of the clamp attaching to the seat system somehow .
There is a small butt hinge on the end , maybe it hinged out of the way ?
thanks for post dusty
My guess is that the hinge was added after the original bench fell apart and it may have been mounted on something else. Something like that could be easily adapted to stabilize the end of a board being hand planed, if it was on a mount, adjustable for height and distance from a bench vise.
Lacing horses generaly had a tightner that was a leather or rope string that was tied to one side, and then run through a hole bored in the other side, to a foot bar. One side was fixed, one movable, alowing grip to be quickly applied and released. This tightener looks more like a saw sharpening jig.
ptu,
If you look closely, you can see the holes thru the jaws for the rope to pass thru. I believe the hanger bolt attaching the jaws is a later replacement. That and the absence of any file marks at the top of the jaws, makes me think it is for leatherwork, rather than saw sharpening. Saw vises will typically have somewhat wider jaws, if for handsaws, or arced tops if for circular saws blades. Gotta admit, the dovetail sockets are a puzzlement.
Ya you are rght, I can't figure the dovetails.
Ray & ptu highfigh , others ,
Here is an inside view of the dovtail and guts , hope we can get to the real use of this item .
thank you all for playing
dusty
dusty,
Here's my theory, and I'm sticking to it: Normally, one leg of the vise (for a stitching pony, lacing horse) has a tenon that extends thru the seat of the pony, where it is wedged underneath. Looks like yours got broken off. The better ones have a spring somewhere between the jaws so that they will open when the pressure exerted by the closing device is released. I believe that yours had a rope originally, knotted outside the smaller of the pair of holes (on the moving jaw) that are above the hangerbolt. The rope went thru the larger hole in the other (fixed) jaw, and was tightened by foot pressure on a pedal near the floor. I'm guessing that the dovetails held a short length of thinned springy wood, like hickory or ash, that either didn't work as planned, or was broken in the accident that snapped off the wedged tenon.
Thanks Ray ,
I'll buy that ( I guess I already did )
To me it looks to flimsy to hold saw blades .
regards dusty
Ray, I would expect that you have at least one "old fella" in your neck o' the woods that probably wore out two of these. How about some research here. It couldn't cost ya more than a couple o' sips of good corn liquor. Paddy
Paddy me lad,
Heck, I have the one my grandpa used on the farm to repair harness. It was lacking the rope when I pulled it out of dad's basement, otherwise still usable.
PS tried to attach a pic, no luck
I think the dovetail structure was part of a post/hinge setup, the hinge there being added later. Are the jaws lined with something?
Dusty, I here by recind my previous saw vise judgement(sorry Troy). I actually found my very old saw vise and while there is a resemblence, there is too much free space under the clamp edges for a saw. It does look like enough space to gather a fair amount of leather or canvas fabric to stitch . I does look very old and has seen serious service. Paddy
I'm also voting for a leather holding device.
Thank you very much to all ,
Let's call This case of myth busters closed , leather tool it is .
Who's turn next ?
dusty
