What’s wrong with my router? Mysterious problem.
![](https://secure.gravatar.com/avatar/c2bf98c80a462904832a7b1da03d6727?s=52&d=https%3A%2F%2Fimages.finewoodworking.com%2Fapp%2Favatars%2F200x200%2Ft.png&r=g)
My Bosch 1617 plunge router drops 1/16″ after a minute of use. It doesn’t matter what bit I use (1/4″ or 1/2″ collet, dovetail, dado, spiral up cut…). I thought it might have been debris in the collet so I lightly touched it up with Emory cloth on the inside. I cleaned all the router bit stems with wet dry sand paper. I cranked the bit down extremely tight just to be sure. Bits are inserted all the way in and backed out a little to give room for heat expansion of the stem. I tightened the router body clamp tight when attaching to the plung base. Yet, it drops 1/16″ each time. I am totally stumped. Anyone seen this before?
which
What drops? the bit or the whole router?
Forrest
