What’s your favorite method for makin…
![](https://images.finewoodworking.com/app/uploads/2016/09/07205055/photo9_sqm.jpg)
What’s your favorite method for making tenons?
- Commercial tenoning jig for tablesaw
- Shopmade tenoning jig for tablesaw
- Dado set
- Bandsaw and tablesaw
- Handsaw
- Other (post in Knots)
You will not be able to change your vote.
Since I got my Domino over a year ago, I have not made a "traditional" tennon. I used to make them on the band saw though...
Peter
www.jpswoodworking.com
"Other" = Domino
Better life through Zoodles and poutine...
David,
Since I'm in line with getting one of those tax refunds and not wanting to irritate the poilticians in Washington I now use gov't specs. for laying out tenons:
Measure with micrometer, mark with chalk and cut with an axe. Then file to fit.
Other: Purchase loose tenon stock from Lee Valley and use a router jig to make mortises in both halves of the joint.
But I do cut some tenons, and most half-lap and bridle joints, on the bandsaw.
Other: Leigh FMT, chose this over Domino...
Leigh FMT
David,
I got the Vega machine, which uses a router motor and upcut bit. I think they are out of business now, but I read about the machine in a FWW article several years ago. It was relatively inexpensive, and makes repeatable, accurate tenons. Relatively easy to set up/ adjust. Cuts angled tenons, and round self tenons(attached dowels, as it were) and allegedly, box (finger) joints as well, tho I've never done the box joint thing.
I use a cheese grater and fuel myself with a 12-pack of Pabst Blue Ribbon.
http://www.ithacawoodworker.com
They still make Pubers!? 16 ouncers?
Yes, I drink only the finest of beverages;)
Pass the Sapphire, please.
I like the woodrat best, as it makes piston-fitters.
But I use all them other methods, as well as the router in various guises, just to play. Which one shall it be termorra? I just don't know until I steps into the shed.....
Lataxe the inconsistent.
Me too... Woodrat
David,
I use a tablesaw and the standard 1/8" kerf blade. I clear most of the waste using the miter gauge and the fence as a stop before sliding the workpiece across the blade with the miter gauge as a fence.
Most of the tenon I make are fairly short, so I use the table saw with a standard blade and the miter gauge.
Rick W
Loose tenons, David.
Cut mortice in both components with a horizontal mortiser and use available scrap to manufacture tenons to fit.
Cheers,
eddie
I love my Domino. (Anyone in England want to buy a redundant morticing machine?)
I haven't made atenon since I bought the Dowel Max about a year ago.
I'm old enough to have, and still use a radial arm saw.
David:
I use a shop-made horizontal routing attachment, fitted with a Bosch trim router which attaches to the shop-made router table/table extension on my table saw.
dewesq
Other = cut on the table saw, regular blade. Easy, minimal set up, no jig required.
I have been making mortise and tenon joints, although small, using my Epilog Laser machine. I just superimpose a square on the edge of a piece for the tenon, delete the center and inside lines, and make a corresponding rectangle as wide as the wood is thick for the mortise.
Grouter.
I use a variety of methods but the one I'm liking most these days is my Leigh FMT.
I typically use a tablesaw jig I made which glides on the fence, to get the job done faster. But I really enjoy cutting tenons and mortises by hand for fine furniture pieces. Nothing bets the satisfactionof looking at a join that is perfect and you cut it with you own hands.
I guess if I were making a bunch of tenons, I might be interested in a jig/tool for the job, but for the way I work, a marking gauge, saw and shoulder plane is my favorite way to go.
I thought I would like the bandsaw, since it is my most used power tool, but it didn't turn out to be the case.
The only time I use anything other than the handsaw, is for wide tenons like those on slant front desk lids or sideboard sides and backs, where I use the router and fence.
Rob Millard
nice web site and BEAUTIFUL furniture!
Jeff,
Thank you.
Rob Millard
For one or two, I don't bother with the dado set, I use the tablesaw with a single blade. I didn't try my Delta tenonning jig yet, but I bought it particularly for angled tenons. I like using loose tenons because it's fast, versatile and accurate (when setup is done). I plan to build Ernie Conover's horizontal router table from FWW #147. It looks great and should helps making tenons very easy and fast.
Serge
I mount two blades in the table saw, spacing them with the inner blades from my dado set. I use shims to get the exact width I need to match the mortices I cut in the rails. Then I use the Delta jig to hold the rails and pass them through the saw. I use a shoulder plane to perfect the fit.
I made all the doors in my house this way. The tenons were 2 1/2 inches long land about 3 inches wide 1/2 thick. Cut the mortices with a morticing machne. Fit pretty well. Pegged all the joints.
Stef
Single end tenoner or spindle moulder with appropriate tooling. At a pinch I'll use a bandsaw, though. Tablesaw with unguarded blade is too dangerous for my liking
Scrit
Nuclear-powered laser cutter on a CNC machine. This is set up on a hydraulic jack and vacuum clamp to make sure nothing moves during the vital cuts.
However I still prefer to use a backsaw, shoulder plane and occasionally a steam-powered bandsaw at times.
I use a shop made jig for the router. It can handle mortises as well as tenons.
Not an original idea, I saw it in shop notes or woodsmith one of those.
It works best with an up cut spiral bit!
Chaim
Make your own mistakes not someone elses, this is a good way to be original !
I like your hammer wind chimes in the background....;>) AZMO <!----><!----><!---->
-----------_o
---------_'-,>
-------(*)/ (*) http://www.EarthArtLandscape.com
Thanks I have people inquire of it from all around but your the first to see it for what it truly is... Modern Art!
Thank you once again.
Chaim P.S. I like your work But I noticed that there are no wind chimes.
Edited 5/3/2008 2:19 pm by chaim
I have also just purchased the Domino and in many cases prefer it
to the traditional mortise and tenons.
I am building the interior doors for our new house. The Doors are four panel doors.
http://www.superwoodworks.com/Projects/PanelDoors.htm
On the last door I used the Domino to make the loose tenons. The doors are very rigid and machining /assembly time was less. As a result I will likely be using the traditonal methods less in the future.
I use a tenon jig I made from a plan from Jim McCleary of provenwoodworking.com with a plunge router with a rabbeting bit. It makes pretty tenons that are obscenely crisp and square. Key is a router bit with a long shank and various sized rub collars. I believe this is also what Pat Warner uses (or may have invented) as well and he sells jigs pre-made along with long router bits.
This is a very safe method and with a dust collector on a router a pretty dust free one.
I use floating tenons. IMO easier and just as strong and provided some flexibility in adjusting. (domino)
Edited 5/4/2008 8:54 am by bones
When doing exterior joinery on items like doors, sash windows, etc I was taught to use through tenons with wedges and glue every time. the reasoning is simple - even if the glue joint fails, the wedges will retain structural integrity. I've seen quite a few Victorian (i.e. pre-1900) sash windows and doors made in this manner which are still in one piece so somebody must have got the original design right. Are you sure that a joint depending totally on glue will actually outlive you?
Scrit
