I need to build at least one temporary, outdoor wheelchair ramp for my daughter. I was going to use treated plywood over a 2x frame. Anyone have any tips?
Plywood tends to be slippery when wet. Roll asphalt roofing, with the granules, is inexpensive and would provide good traction if applied down the middle.
There are lots of other design considerations, like railings, toe-kicks, landings, space to turn, lighting, etc. Suggested slope is 1:12 maximum, with 1:20 recommended.
Here's a site http://www.access-board.gov/adaag/html/adaag.htm#4.8
Of course, being non-public, temporary, and intended for a specific disability you could compromise as needed.
If you have other questions, just ask.
Roofing paper, eh? I was thinking of some sort of rubber mat, but the roof paper might be the way to go.
Thanks for the input. After reading the citation you sent I've come to realize there's more to it than I'd thunk. I would certainly have been off on the rise/run ratio.
In addition to the on-line resources, a service organization in your area may be able to assist with the design, labor, and/or materials. In some areas, I seem to remember trade labor (carpenters union or area AFL/CIO) donating their resources to accomplish this.
Good Luck and Good Skill!
tony b.
I built a wheelchair ramp for my father last summer. There's a lot of information at web sites for wheelchair users. You can get dimensions for clearances, and advice on design. The Americans with Disability Act (ADA) rules can help, even if you don't follow them.
I'd post over in Fine Homebuilding as your question is more carpentry related than furniture related.
Hello,
Consider putting some sort of organic pesticide under the ramp, such as boric acid or diatamacious (I can't spell) earth to prevent cockroaches and other bugs. My house had a ramp when I moved in. The ramp was an excellent breeding ground for bugs.
Chuck
If you need help with building it, I'd contact your local Lions Club.
I've been a Lion for 17 years and have built at least two handicap ramps a year during that time. It is what service clubs do.
Architectual Grafic Standards will tell you mre than you will ever need to know about your ramp. The libary will or should have a copy.
Who ever invented work didn't know how to fish....
