I have been useing a solvent bassed stain applied after applying a sanding sealer. I am thinking about switching to a water bassed sealer. I am confused however, when is the right time to apply the sealer? Before the stain, before the finish coat? or????? I have read & heard several diff. opinions on this. What is right?
Thanks for the input
stain first, then sanding sealer, then finish coat.
water-based sealer over solvent-based stain may not adhere properly--you could use wax-free shellac instead.
