Being very much a learner, with no tutor in human form available, can you tell me if its ever ok to glue a joint and then drill the holes for dowels, so fitting and gluing them the joint is glued hard.
I'm not sure I understand your question but I'll do my best to answer.
In many cases it is acceptable to glue a joint and then reinforce it with dowels or pins. In fact, mortise and tenon joints are commonly pinned.
Here is an article that illustrates the pinned box joint, another joint that benefits from pins:
http://www.taunton.com/finewoodworking/SkillsAndTechniques/SkillsAndTechniquesPDF.aspx?id=2894
Matt Berger
Fine Woodworking
Thanks a lot for answering my question, and I'll do the reading first chance I get.
Kind regards
