I was planning use sanding sealer on some pine trim before staining it. The paint store says sanding sealer is illegal (good ‘ol NJ EPA). Is this true? I had not heard of this. What is available to use in it’s place? Thanks for any help.
Depends on what you are doing...I have used a washcoat of super blonde shellac on pine and that has worked better than any sanding sealer I have ever used. You can buy the flakes and make it yourself or I think they may sell it ready-made at the big boxes or paint stores. I use something like 1 part shellac to 3 parts denatured alcohol or something. Mess around with it until you get the right mix.
I recently made a large table and I wanted to leave the top mostly unfinished, but it needed to be stained. I applied linseed oil first, rubbed it in and wiped off the excess, then put the oil-based stain on immediately afterward. The color was not as even as it would have been with a washcoat of shellac, but that's what I was after.
That's what's worked for me; I'm sure others will pile on and tell me I'm a hack, so take it FWIW.
Zinsser sealcoat is available. It's basically a 2# cut of dewaxed blond shellac.
I believe Minwax makes a product they call "Sanding Sealer". Not sure if it's anything different than just blonde shellac, but they sell it at HD and you can probably check it out on the Minwax website.
Most sanding sealers do not meet state VOC emission standards. There is no way to make them fast drying without exceeding these standards.
You can probably expect that all solvent based finishes will fall by the wayside in the next few years. For all intents and purposes, California is headed that way. Whatever California does, other states with poor air quality will follow. The NYC area is never far behind.
That said, there are a number of alternatives which are as good, if not better, than sanding sealer.
Edited 3/19/2006 11:54 am ET by HowardAcheson
Edited 3/19/2006 11:55 am ET by HowardAcheson
So far at least the Zinzzer Seal Coat is still available in CA. Keepin my fingers crossed! Can't get Waterlox though :-(.
Lots of WB high-build sealers out. Check out Target Coatings. Go to http://www.homesteadfinishing.com
Zinser seal coat....works very well. Another way to go is yellow wood glue. The same principle as when you have stain that didn't work in the'squeze out areas' but dilute it. Pro Bond, Elmers, Tite Bond etc. Mix ratio is APPROX. 1/4 cup of glue to 2+ cups of luke warm water. Using a foam brush, apply it like you were painting the solution on (using a pc. of SCRAP FIRST) and let dry. After drying apply stain to pc and see if it will stain dark enough for you. By adjusting either glue ratio or colour of stain, you can 'dial in' the right look for what you're trying to achieve. Done correctly, this will allieviate all blotchy areas associated with trying to stain pine and or cherry wood. Works like a shellac wash. To save you money in Tylenol, make sure you try this on scrap wood first. Good Luck !
Hi
Diamond Vogal stores carrey sanding sealer. Just bought a gallon last week.
Have a nice day Lee
Thanks to all, past and future, for your help. I did find a shellac based sanding sealer at another paint store in the same town. Will post when the project is finished to let you know how it came out.
(how much damage can the vapors from a pint of shellac or stain do?)
