I need 3/8 inch as dark cherry as possible dowels to build a cradle for an on-the-way grandchild.
Where can I order some?
Alan – planesaw
Alan – planesaw
Cincinnati Dowel & Wood Products::
Cincinnati Dowel and Wood Products is your best source for dowels, plugs, pins,
buttons, pegs, and biscuits. Species include: oak, maple, poplar, beech, ...
www.cincinnatidowel.com/ - 11k - Cached - Similar pages
Thank you!!!!! I'll check 'em out.
Alan - planesaw
Another choice is Midwest dowel, on the west side of Cincinnati:http://www.midwestdowel.com/
Darbynwoods and byhammerandhand --
Either of you know whether Cincinnati or Midwest is better? Quality of wood? Midwest is fair amount higher than Cincinnati.
Alan - planesaw
I have only used Midwest and have been happy with them. They are a manufacturer, not just a retailer. They used to be close to where I lived before we both moved out a bit.
Alan
If you get stuck, as I have on occassion when I required an odd species, try using a 3/16" round over bit in the router table. Just machine up some 3/8" square cherry. I've found that relatively short lengths are best, say 12-18", preferably less than the depth of your router table & if you don't route the whole length, leaving for example an inch or two at each end to bear on the fence & table the stock doesn't tend to twist during machining & four passes will do the job. I hope this doesn't complicate what is a pretty simple job.
Don
Thanks. Hadn't thought of making them that way. Since I need about 45 to 50, I will probably buy some.
Alan - planesaw
Alan
I just bought 50 3/8" cherry dowels from Woodworkers supply.
http://www.woodworker.com
Catalog no. 203009, cant find what I paid for them though.
Doug
I bought from Woodworkers Supply the last time. Took two or three times for them to get the order straight and I was late with the project as a result. They sent white, then 1 inch, then a variety before getting what I ordered. I know anyone can have a bad day, but I can't afford the delays again.
And, if Cincinnati's are good quality then they are considerably cheaper. I am giving them a try.
Alan - planesaw
Buy a dowelling plate from LN, and then you can make whatever size dowels you need from any wood you want, at your convenience.
I second that thought
Peter
I need about 60 dowels. I have no experience with the jig/plate you are talking about. How good is the finish on a dowel you make? How do they work?
Alan - planesaw
Alan,
Making a dowel is real simple: take a piece (square, roughly round, etc) of wood that's more or less the size of the desired dowel diameter, chamfer one end and insert it into the appropriate size cutting hole; then pound the wood through with a wooden or deadblow mallet. The finish is pretty smooth, at least with those I've made so far. At most a little touch up with some 220 sandpaper is needed.
Here's a link to the dowel plate on the LN site.
http://www.lie-nielsen.com/catalog.php?grp=1239
There's also a link to a good article on dowel-making by David Charlesworth on the above web page.
James
