Kevin
Just read your Apr 24 post about PM acetate/MEK blend and I’d sure like to try it. Where would an amateur like me get PM acetate.
Also I’ve heard good things about IBIB. Do you know where that could be obtained?
JC
Kevin
JC
Well, I get PM Acetate from my local Sherwin Williams commercial finishing outlet. While that division of SW is clearly set up for commerical accounts, I suspect that they'd be happy to take your money. There are, or at least used to be, other local sources as well as I know that former employers in the area purchased PM Acetate from other sources.
Perhaps the best bet if you can't readily find a local source would be to call a local cabinet shop that is using solvent-based finishes and ask them where you can buy solvents. They might even be willing to act as purchasing agent for you if need be.
As for IBIB... I don't know what that is. I assume it's some sort of isobutyl acetate? There are actually a number of retarding solvents in the acetate family which can be used in lacquer. I prefer PM Acetate because it's fairly weak, and also because it's a primary solvent for nitrocellulose resin.
A weaker retarding solvent is easier to work with, IMO, because a splash too much or a splash too little has much less effect than with the stronger retarders, making it much more forgiving. For example, 10% reduction with PM Acetate is a fairly normal reduction schedule recommended by the SW lab guys. Glycol ether EB (this is from memory and might not be exactly the right name) has a reduction schedule of 1-2%. It's much easier to eyeball reduce with PM Acetate because it's weaker. With the glycol ether you'd want to measure accurately because it's so strong of a retarder. One percent too much of the PM isn't a big deal. One percent too much of the glycol is a huge deal.
"Rather fail with honor than succeed by fraud" - Sophocles.
Thanks a lot
jC
