Every place I’ve checked so far only has boiled linseed oil. Anyone have suggestions on where to find raw linseed oil in gallon quantities?
PlaneWood by Mike_in_Katy
PlaneWood
PlaneWood
Here's one. http://www.parkscorp.com/solvents.html 5 gallons, gallons, and quarts. There's a store locater link on the page.
Have you Googled?
Unk Dunk -
Yeah, I've googled! Also tried the local HD, Loews, Kmart, Target, Shermin Williams, and turned up nothing.
Boiled linseed oil has additives that I do not want. I am wanting to cook my own varnish.
Art supply stores have it, as well as Stand Oil, sun bleached, etc but usually only in pint quantities at a very high price.
Thanks!
my local farm and home has raw linseed oil by the gallons. fairly cheap too.
Here are a few more.
http://www.runninghorseranch.net/ProductsList.htm
http://www.eezimmermanco.com/products_files/LinseedOilRaw.html
http://www.barrettine.co.uk/woodcare/oils.htm
http://www.jamestowndistributors.com/cgi-local/SoftCart.exe/store/product_list_pages/Solvents_Linseed_Oil.html?E+scstore
Mike,
Very interested to find out how the varnish cooking goes. I've heard that true heat polymerization of linseed oil is an extremely invlolved, complicated process, and I'd like to know if it deserves this mystique or not. Let us know how it turns out.
Not really, kinda like making candy. You bring it up to temp and leave it there till it forms a 'soft ball' in cold water of on cold glass. Temp is about 375-400 * F. Just don't use an open flame or do it inside.
just looked at my farm and home store. FYI raw linseed oil there is 12.50 gallon
There's more to varnish than just "cooked" linseed oil. Cooking linseed oil to a certain temperature and holding it there for some period of time is the old fashioned way of making "boiled" linseed oil. Going to an even higher temperature creates a product called polymerized linseed oil which means it will dry more rapidly. Tried & True is a polymerized linseed oil as is TruOil. But, neither is varnish in spite of what T&T calls their product.
Vanish is a product that results from mixing and heating both an oil (linseed, tung or most often, soya) and resin (phenolic, alkyd). If you want poly varnish, add a little urethane to pot.
Now, why would you want to make your own varnish with all the different types ready made?
Cause the stuff I'm makin ain't ready made! Plus, it's a challenge.
Planewood,
You do know, of course, that linseed oil is one of the best oils to consume for your health. I won't go through the nutritional aspects, but I think the good stuff is cold pressed. Do you think this would work for your project? perhaps the supermarket or the health food store would be your best bet, albeit a bit expensive. BG
Well I checked 3 farm & ranch stores today and no one had any. Going to start calling paint stores tomorrow. I wonder if tung oil would cook up like linseed oil??
PlaneWood
Call Finisher's Supply at 410 Bluebell, 281 448 1371, or Murphy Bros. Paint supply on Bissonnet, 713 529 3485. Both these polish supply houses carry it, or at least it was just sitting on the shelf in gallon containers when I was last at either. Slainte.RJFurniture
Sgain - called those places and neither had it. Only had boiled linseed oil.
Found a paint store that can order it in 5 gallon containers. Was about the 20th I had called. Benjamin Moore paints on west Memorial. No feed store in a 50 mile radius has any. Appears that Cottonseed oil has replace Linseed oil with the cows and show people.
For those of you wondering, I'm going to cook my own Pontypool Asphaltum.
Thought you were cookin' up Kickapoo Joy Juice.
How long, you gonna let it ferment?
Rich
3 hrs. I like my joy juice raw!
Yum!
Hmm. Sorry about the bum steer Mike. I could have sworn I saw it on the shelf at both, but I must be mistaken. At least you didn't waste any fuel driving over to either, and you seem to have found a source. Slainte.
