This weekend I am having a walnut tree 17″ Diameter x 16′ long cut by a guy here in central Illinois. He has a horizontal bandsaw mill. (Woodmizer). I am going to cut this log in half so I will have two eight foot logs. My question is where should I sticker and stack this lumber for air drying? Outside exposed to the elements or in my garage which is not heated or airtight. I could also put it in my workshop in my heated basement. Any suggestions?
The stack shouldn't get rained on, but should have good air circulation, so your garage, maybe with a door and a window open a bit to allow better air exchange, would be best. The ends of the boards should be sealed to prevent end checking. A 17 inch log isn't going to yield a lot of heart wood.
John W.
I stack my green lumber outside behind my shop. have a good base up off the ground about 10'' sticker about every16'' and cover it with sheet metal roofing panels. weight the panels so the wind does not blow it off. Leave the sides and ends exposer so the air can circulate. forget about it for about a year for every inch thickness.
Have a nice day Lee
I stacked walnut like the last post said, and forgot it for about two years, when I got it out and started working it the wood looked UGLY but after a pass or two through the planer, it was beautiful. Good air circulation is the key, and be sure to seal the ends. Have fun with your wood when you get to use it.
Trust the last two posts. After you take the first full width pass from your plane and the silky smooth curls come off, the air drying will be worth the wait.
Depending on where you live will depend on how you orient the stack. Most problems will occur on the ends if the air movementr is too much and it gets quite hot. Most high quality lumber mills and veneer producers will coat the end of their logs before slicing and expensive lumber waiting for it to dry. Sometime if you go to buy some lumber notice if there is a fairly heavy coat of a waxy material on the end.
When lumber is dried in a kiln the ends are exposed the least so that the air moves through the stack. The stickers are 3/4" x 1.5" and are kiln dried. In a kiln if there are any problems it occurs back to the point of the first sticker. That is where the most air movement will occur if it isn't done right.
