Hi guys,
I’m new to the forums, so I’ll do a quick intro and then post my question(s), and see what you all think.
I am an industrial designer for a furniture company in Adelaide, South Australia. I also have experience as a wood machininst and some joinery experience but wouldn’t consider myself a real “wood worker” yet. I did a 6 month wood working course in 2001, where we learned mortise and tenons, dovetails, dowels, biscuits etc and built a nice chaise lounge which I still have at home and a side table which my Mother still has, a step ladder and a cubby house.
I then went and did wood machining, polishing, assembly, upholstery for a gymnastics equipment maufacturer for 5 years which is where I found my love for design. In 2006 I started my industrial design degree, which I graduated from in 2009. From 2009 to 2012 I worked at a foundry, designing tooling for taps and valves for non-ferrous casting (aluminium, brass, copper, zinc). Ejector plates, 0.005 tolerances and shrinkage calculations.
In late 2012, I found my current job as a designer for a big furniture company. We have 100 employees and a huge warehouse of machinery and tools. It’s an amazing place to work and I love it. I design in solidworks and render in modo, build prototypes and do a lot of problem solving.
Now, to my question… I want to get back into building more furniture at home. I have a decent sized workshop and some basic tools, but I have a possible job to design and build some tables for a winery and want to use this opportunity to get some tools and set up my workshop a bit better.
I currently have a cheap but decent circular saw, a triton router, a few drills, chisels, clamps and a groz vise. I am thinking about what I would need to make some nice tables out of reclaimed timber and do some nice joinery. I can get my timber planed at the lumbar yard, but would prefer to do it myself.
I am thinking maybe my first purchases should be the vertitas bevel up jointer plane, a drill press, a good hand rip saw and hand tenon saw and a radial arm saw. That way I can flatten my timber and square it off, cross cut it, drill out and chisel my mortises and cut my tenons. I do want to build up as I go and make a great wood workshop and start building furniture for friends and family.
Any advice would be great! Sorry about the essay length post.
Cheers guys,
Aaron
I concurr with your decisions about the tools you want to buy, My only concern is with the Radial arm saw...
For a drill press, don't buy a cheapo, they are notoriously underpowered. Minimum 5/8 chuck
And radial arm saws are a thing of the past, so if yer heart is really set on one, offer rediculously low price, and do get a carbide bade with it. Why- they simply require too much set up time to cut true, square, and to cut tennons. They were replaced by chop saws 20plus years ago. Most used tool dealers won't even take them in these days. Cheap is operational word, and again hopefully with a carbide blade.
And Chisels? you didn't mention them. Talk to Stu Minuskin at the tool exchange (AU)- he can likely help you out in that regard for a good set of users, and other tools for that matter.
Does wanting a jointer plane mean you already hve the 2/3/4/5/7planes at hand? or is it amn alternative t for an electic jointer. (faster and better due to longer bed) And using a hand jointer plane in lieu of an electric jointer does require a jointer fence attachment to edge joint boards for a modicum of success
Eric in
Canada
where to start with tools
i would sujest getting a , table saw, miter saw, kreg drill, thickness planer, jointer. the table saw for making long streight cuts for the top of the table, miter saw for ctting the legs, a kreg drill to attach the legs to the table, thickness planer and jointer to make the legs to the right size, and possibly a router crafter for making fancy tabel legs.
