Just tried to get to deltamachinery.com which is the top hit on Google for the Delta web site, and the link I had bookmarked, but it comes up dead. Anyone have a newer link? I need some parts!
http://www.deltaportercable.com/
Mike Hennessy
Pittsburgh, PA
Hi forestgirl,
Delta doesn't sell parts directly. Go to http://www.servicenet.com or a local service center to get replacement parts, although not everything is available for older equipment.
Paul
Edited 7/27/2007 12:24 pm ET by colebearanimals
Thanks, you guys. Just need a couple of screws for the 690, nothing in the hardware store worked.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Which screws do you need?------------------------------------
Hi, Don. I need the screws that hold the fence to the base. The part number is 803160, and there are two of them.
Have no idea what in the world I did with mine. The ones from the plunge router don't fit.
They're oddball, I measured mine and they are 12-20, the size is easy to find but I don't think that pitch is common. I did a quick search and did'nt come up with anything. I'll check to see if I have an extra set.------------------------------------
Hey, thanks Don. I hardly ever use the edge-guide, but it was a drag the other day when I wanted to and didn't have those screws!forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Is it possible the screws are metric?
Not according to my calipers, thread pitch guage and screw chart. I did consider that at first although I thought it unlikely since every other part on the 690 is SAE. I figured the safest bet was to measure it and look it up.------------------------------------
I found a spare set, email me an address to send them to and I will pop them in the mail.------------------------------------
Hey, Don, thanks so much! Email on the way. What kind of jam do you like? I plan on picking up a homegrown treat for ya!
Edited 7/28/2007 9:10 pm by forestgirl
If you happen to need more, check out this assortment for a handful of change.
http://www.leevalley.com/wood/page.aspx?c=2&p=41782&cat=1,43000,51208
Chris @ flairwoodworks
Unfortunately none of those will fit.------------------------------------
