Which Bandsaw blade to buy? General use
Hi, I just picked up a 12″ Jet BS on craigslist for pretty cheap. It didn’t come w/ a blade. For general use (tapering, dovetails, etc), what blade (teeth, width, else?) should i look to pick up? I don’t plan to resaw w/ it.
Thanks for helping me out! Brad
Bandsaw
Hello,
I have a delta 14". I have not used the 12" Jet but I'd think that it would work fine if you use a pretty high tension on the blade to prevent the blade from wandering around.
Ed
choices
For general work, I use Olson blades, which are reasonably priced and work well. They have a tips sheet on their site that helps in selecting the right blade:
http://lib.store.yahoo.net/lib/yhst-16765698503918/Bandsaw3-pg.pdf
You may also find this article by Michael Fortune to be helpful:
https://www.finewoodworking.com/FWNPDF/011173066.pdf
Hi Ralph, thanks for steering me in the right direction. Brad
Which blade
Depends a lot on what you plan to do with the saw. Charts like this can help you understand the basics: http://www.kvwoodcarvingsupplies.com/Olsen/Olson%20Band%20Saw%20General%20How%20To's.pdf
If you have the model number you can download the manual.
http://www.jettools.com/us/manufacturing/en/service_support/manuals.html
Get the correct length blade.
Don
thanks Don
Don, this is perfect and very enlightening. Thanks! Brad
you use a band saw to cut dovetails??
Motorized Frank Klausz
Bandsaw for dovetails is the motorized version of Frank Klausz's bow saw ;-)
Chuckle
Plus, the bandsaw is all forth, no back. So, that's gotta cut the time in half to start. ;-)
1/2 the time ??
That is questionable !! Ever see Franks one minute utility grade dovetail video? ;-)
http://www.suffolkmachinery.com has always given me great advice on blade selection and the blades have always performed well.
Suffolk "Timber Wolf"
Been using Suffolk blades, and except for a couple of blades with bad welds (which were replaced at no charge) have found them to work well for me. I use their 3/8 x 4 PC (4 teeth/inch pitch) for all around work. Excellent cutting, little or no wander, and the minimum radius of a 3/8 blade is given at around 1 1/4 inches. It would be a good blade size to start with, and it will do a respectable job of resawing when needed.
Bandsaw blades
Hi Brad... As others have mentioned, Timberwolf blades from Suffolk Machinery are tops. They are very helpful in helping you selecting the proper blades for you to use. Ask anout any special 'deals' for first-time buyers. Sometimes they have a buy 3, get 4 special.
I get most of my blades (Olson Brand) from Armor Crafts http://www.armorplans,com. Scroll down on their front page to 'scroll band blades. Click on it, and you will get to their saw blade page. The Olsen chart is at the very bottom. They do not have the wide range that Suffolk Machinery has, but they do stock the most popular sizes. The guys ARE woodworkers and know what most people will buy.
Since most of my work is making small toys, I generally use the 3/16 x 4 TPI and the 1/4 6TPI. Occasionally, I will use the 3/8 x 4 TPI and rarely, the 1/2" x 3TPI. Yes, I have other blades, but these are the ones I use 95% of thge time.
SawdustSteve Long Island, NY (E of NYC)
bandsaw source
I use a 1/2' 3 tpi blade for most work and sometimes a 1/4" 6 tpi blade. I recently ordered some 1/2" bimetal blades from Woodcraft Bands. The price was ~2/3 of any other source (under $40 ea. for a 150" blade). Seem like really nice folks, shipped the blades that day.
http://www.woodcraftbands.com/Pricing%20page.htm
Good luck,
C
bandsaw blades
I have used the 1/2 4tpi timberwolf blades and I just put in a 1/2 3tpi from bc saw and tool have you used this blade before
thanks
Thanks again to all.
I looked at a couple of the sites mentioned, but shipping killed the value, so I order a timber wolf from woodcraft that includes free shipping.
1/2" x 82", 3 TPI Timber Wolf Bandsaw Blade
- Brad
bandsaw blade
Hi there,
I love using a site called http://www.abetterblade.com
They have tons of sizes and will custom make any blade you need.
They also gave me free shipping and answered all my questions.
check it out
