Hello All,
I don’t anticipate this happening often, maybe ever again, but the power went off the other day while I was using the tablesaw. I was suddenly standing there in the dark feeding a piece of wood with the sawblade still turning. There was no harm done, but it really made me stop and think.
Do I want the tablesaw (small contractor’s) on the lighting circuit, so if the lights go out the saw will go off too?
Then shop for and install a magnetic switch so once the saw drops out it won’t come back on automatically with the lights?
Is my thinking right on this?
Thanks!
Jonnieboy
Edited 6/15/2009 11:34 pm ET by jonnieboy
It is recommended that lighting circuits be separate from heavily-loaded circuits, so that a tripped breaker won't put you in the dark (lighting-only circuits very rarely trip a breaker). Residential code does not require it, however (except maybe in the kitchen--I don't recall offhand).
I don't quite understand your first question. You're talking about an actual power failure, right? If so, then both go off at the same time, whether or not they're on the same circuit, no?
As for the second question, yes, it's always safer to have a magnetic switch to prevent restarting, but once again, code doesn't require it on smaller equipment.
Steve,
You are correct. In this case it was both circuits at the same time, because it was power to the whole house. But that got me thinking about the other, if the lights and saw are on separate circuits and only the lighting circuit trips.
As a used-to-be electrician my first thought is to put the saw on a dedicated circuit, even though it has a relatively small motor. But I'm not so sure anymore.
Like I say, it's bound to be a rare occasion. We're in the city with reliable utilities. I'll start by installing a magnetic switch of some sort.
Thanks!
Jonnieboy
Steve,
Duh. I'll just put a light or two on the circuit with the saw. I already keep the saw circuit lightly loaded to avoid nuisance tripping. I'll continue to do that, plus add the magnetic contactor.
Jonnieboy
I have circuits for all the power tools that are separate from the lighting circuits. Flesh-hungry carbide teeth scare me in the dark.For total power failures, there are safety lights available that come on when main power fails. They operate on rechargeable batteries tied into a charging circuit.
The emergency lighting is a good idea.
What I've done for now is put two lights on with the saw circuit. They are near the saw, but not the one directly above the saw. All the other lights are on a separate circuit, including the one directly over the saw.
Thinking this way: Lighting circuit trips, I still have light. Saw circuit trips, I still have light.
All situations covered except for total power outage. Emergency lighting unit and magnetic contactor are on the shopping list.
Thanks for the feedback, guys!
-Jonnieboy
"What I've done for now is put two lights on with the saw circuit."
I really don't understand the logic here (I was going to reply to your previous message, but I forgot about it). Dedicated lighting circuits never trip their breakers.
Hi Steve,
I agree, the lights won't trip their breaker except in the rare case that a ballast goes bad in just the wrong way, or something else very weird happens. Just me over-thinking it again.
Thanks again for the input.
Jonnieboy
Come to think about it, flourescents don't even have ballasts anymore, do they?
-Jon
They do. Generally, they're electronic ballasts these days, which are smaller and lighter. CFLs have the ballast inside the base of the bulb. (Really cheap fluorescent fixtures still have old-fashioned electromagnetic ballasts.)
I believe putting the saw on a lighting circuit is a code violation. You don't want to trip a breaker and be standing in the dark while the blade spins down.
A mag starter would give you an additional level of safety since the saw will not start back up unexpectedly after a momentary outage.
Pete
Not only do you want separate circuits for tools and lights, you want more than one lighting circuit, so there is very, very little chance of being left in the dark.
Brian
Brian,
Now you're talking. That's a great solution. I'll feel much more comfortable with that. My shop walls and ceiling are all open so it's no big deal to split circuits or add extras. Up to a point, of course.
Jonnieboy
