Which method do you most often use to…
Which method do you most often use to cut mortises?
- Drilling and chopping
- Router with template
- Router with edge guide
- Hollow-chisel mortiser
- Completely by hand
- Horizontal mortising machine
- Other (post in Knots)
You will be able to change your vote.
Domino! Love it fast & easy.
Domino.
Better life through Zoodles and poutine...
Woodrat
I used to do them with a Hollow-chisel mortiser or the router.
But now I am with the majority above, the Domino
http://www.superwoodworks.com/Projects/PanelDoors.htm
I use both mortise machine and hand method equally.
David,
I built a Tage Frid mortise jig, sometimes called a U shaped jig. WOrks fine with the router. Tage was way ahead of his time.
Mostly for hinges, I use a router with template and the edge guide. But to prevent tear out.
I 'Nick' the entrance and exit edges with a sharp knife first.
Also, don't use guide bushings .Instead, fabricate the templates over sized to guide the six inch circular base of the router.
Chopping out the two radii with a chisel (if not using radiussed butts.)
Steinmetz.
The FMT with a DW621.
Certainly done my share many of these methods - drill and mortising chisel most common but I often do large log constructions and achieve good results with a chainsaw.
David:
Well, the question was: "...most often..."? While I DO use a hollow-chisel
machine (Jet) when speed is important - or when, for whatever other reason
I'm just feelin' 'pissy' - [most often], I prefer the infinitely therapeutic method
of 'hand 'n' chjsels'! I find it calming, tranquilizing even centering if you will.
It just 'works' for me much better in many ways...
Warmly, Griz [email protected]
