Oh, ye wise and knowledgable folks!
It’s time (at last!) to add to my arsenal a moisture meter. I know there will be no lack of opinion among my venerable bretheren and sisteren!.
I won’t be using the meter all day long every day, but I’d like to have one that will hold up a while and give accurate readings in the 6-12% range. I see ads for everything price-wise from $20 to nearly $300, so tell me I’m not confused! Keep in mind that I’m a cheapskate when you post your responses!
Thanks in advance for your advice.
Mensa Member
Click Here if you’re interested in a good, inexpensive website host.
Hey Bill, I don't have a moisture meter yet either, but the one I have my eye on is a Delmhorst pin model, the J-Lite or (if I get rich soon) the J-4 or J-2000). What I like about the Delmhorst is that you can add on a "Remote Electrode" for reaching into stacks of lumber. Said electrode has a hammer on it also to help get maximum penetration.
Jamie,
Thanks. I'd have to lean toward the Lite also -- budget, ya know.
Bill Arnold - Custom WoodcraftingMensa Member Click Here if you're interested in a good, inexpensive website host.
The Lignomat mentioned above is another one that deserves consideration. I lean toward the J-Lite because if I want to, I can add that other sensor to it, but the Lig is supposed to be a real nice meter.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
Bill,
I use a Wagner pinless meter that is about 6 years old. It is probably slightly less accurate than a meter with pins, but for my purposes the ease of use makes up for it tenfold. We commonly have stacks of wood delivered to the shop, and they arrive on a truck before I have ever seen them. I quickly check the moisture levels at various points before I let them even unload the truck. If the meter is off by 1/2% it doesn't matter to me. It is my quick and easy check against shipments that I will not accept. It cost about $100 at the time, and paid for itself on the first stack of wood I sent back to the supplier.
DR
Ring,
Looks like that's the model that sells for about $150 now -- more than I want to spend. Thanks for your input.
try trollong eBay if it is not an immediate requirement1 - measure the board twice, 2 - cut it once, 3 - measure the space where it is supposed to go 4 - get a new board and go back to step 1
Hi, Bill -- I've been using a Lignomat (under $100) for some time, but only to track the relative moisture of wood in my shop. Seems to be fine for that purpose. I don't have any interest in absolutes, just interested in whether a piece is ready to be worked or not. I have some wood from last year's hurricanes and I test it every week or so using the pin meter. It's gotten down to around 12 percent RH which is about what I can use depending on thickness and some other factors, but the meter does what I need it to. Sometimes the meter goes on sale for a couple of bucks less. Jim
Bill
Due to the fact that I mill almost all my own lumber, a moisture meter is pretty critical to my work. I've got a Lignomat, and it has not let me down in the 6 or 7 years that I've had it. It has 2 settings, for the different "types" of hardwoods, and has a chart to refer to, so you have it set for the right species. Easy to use, and it has been very accurate for me. So far, NO CALL BACKS!!!
