I would appreciate your opinions on which handheld electric planer would work best at fitting doors and straightening boards? I’m looking for a simple and durable tool with easy adjustments. The Bosch or Makita seem to get good reviews. How does the Dewalt compare to those? Who makes the longest lasting blades? Thanks in advance.
I have a Porter Cable Elec planer that I used to take some of the crowns out of roof rafters when I built my shop. And thats all I've ever used it for. I use my Stanley 5 for doors. Feel much more confident using it and the results are far superior.
Bruce S.
I have an older Makita and it works well and the blades seem to be easy to replace.. You probably can get a lot of opinions on the Breaktime area of fine homebuilding.
Troy
I have a Makita, only about 3 years old. Works great. Highly recommend it.
Alan - planesaw
Starting at the top, here's a PC which has been the planer of choice for the door hanger crowd for decades:
http://tinyurl.com/yjxczm
There are a flock of planers clustered around $120, and I don't think you could go wrong with any one of them.
Personally, I own a Dewalt and it is ok, and has a good set of accessories. A new blade set (carbide) costs about $16-20.
Among those I have used on sites, I prefer the Makita -- it is slightly smaller than the Dewalt, is very maneuverable , and fits my hand nicely.
I know a fair number of people with the Bosch, I have used one once, and it did just fine.
If you can't spring for the expensive PC above, my advice would be to pick a planer based on ergonomics and dust collection. These things really throw the chips around, and it is nice to be able to contain them. The Dewalt has an odd-ball triangular shaped hole, and I don't even know if they make an adapter for it to fit a shop vac. I did get the dust bag, which is a squarish, klutzy thing, but it works.
P.S. Festool also makes a portable planer, and the price is about the same as the PC. It is the only planer that can cut flush to a vertical surface, and you can buy an accessory stand that will attach to a bench and allow you to use it as a kind of mini-jointer.
Here's some info:
http://www.woodworkersshop.com/Festool_Planer.htm
John Wooden 1910-
"Porta Plane - $865" Oh, Ouch! About thirty years ago the Porta Plane was about two thirds the price of the Versa Plane, as I remember from Silvo Hardware. I was going to be smart and bought the Versa. Over the years, I think it was priced out of the market. I probably paid less than $400. The beds are anything but co-planer. I haven't used it much, never really got to know how to use it, so really haven't had much luck with it. I wouldn't know how to use a hand plane well either but have better luck with them. Some day, maybe.
Well, that's the retail price -- it's about half that from Amazon:http://tinyurl.com/y4b8c4Silvo Hardware ???I bought an awful lot of tools from them back in the 70's. I remember studying the Garrett Wade catalogs (and their great tool descriptions), and then going over to the Silvo catalog to buy the same thing for way less $$.Whatever happened to them? As I remember, all of a sudden they changed the catalog style (probably sold to somebody), raised their prices, and I never ordered from them again.********************************************************
John Wooden 1910-
"Silvo Hardware" Maybe they just sold to cheap. I liked them.
Not a SKIL 100 amoungst the lot?
Another person mentioned the Festol, I have not used this one but one of its neat features is that you can change the cutting head to one that will give you a textured cut to mimick a hand hewn look on beams. An application that I have not needed but kind of interesting.
Troy
We had blades ground for our Makita to do the hand planed texture thing so it's possible to do with any planer, so one is not only limited to a Festool.
Thanks for the tip, where the blades that you had ground steel or carbide?Thanks
HSS knives. Had my sharpening shop grind them. They have a template to make sure they are reground to the same profile. A slight arc, maybe 1/8" crown.
Thanks for the idea. Troy
