Which respirator do y’all recommend to be used while spray finishing? I’ve heard thru the rumor mill that th 3M-7500 series is a good product. Any thoughts? Thanks.
That's what I use for water borne finishes and it's great. Other finishes may need a different type.
"I never met a man who didn't owe somebody something."
The type of filter is dependent on the type of finish. If you are using a standard finish, an organic filter is what will cover most situations. However, if you are using some other two part finishes, you should get a copy of the MSDS from your finish manufacturer. It will tell you what is needed.
