I want to get a new router and would like to know if anyone has had experiences with the Porter Cable 2 HP router, number 97529, or if anyone recommends another. I’m a hobbiest, not a professional, but I do use a router often.
Thanks, Don
Thanks, Don
The 7529 is a good router. The plunge was a little stiff at first but either it loosend up or I got used to it. It is a electronic controlled, soft start, variable speed router with all of the bells and whistles. I've had mine for about a year and use it frequently without any problems. If you buy it as a kit, you get the microfine fence and a case.
Steve - in Northern California
I just completed a MAJOR woodworking project, if you want to call it that. I just finished making siding for an addition to my home, 4,000 sf of 1x12 pine siding. We had to make 8 passes with a router and edge guide. I ended up with (3) Bosch 1617EVS routers. They are by far, the best 2HP router there is, bar none. I burnt up (2) of the new Makita 1101's. I would have burned up my PC 690, but it got too hot to hold, so I quit using it. People say that you can heat them up and they keep on keeping on.
I used (4) Jesada 1-1/4" dado bits for this, and had each sharpened once. They were 4 times sharper when they came back from the local sharpener. You could even tell you were in the wood for 10-12 passes. These 1x12's were mostly 12'-14' long.
The carpenters were there last Friday when a couple of fellas from work took off with myself and finished up about the last 1000 sf. They would watch us for a while and I told them that if they needed a router right now, they better buy a Bosch. They laughed and told us that we would blow those things up. 6 hours later, they changed their minds. Routers are fine. Just glad it's over.
Well, I gotta tell ya that's a heck of a story... I also had a Bosch 1617EVS. I gave it to friend because the PC was so much more sophisticated. I recently ground a 3/4" recess into the majority of the surface of a 8' by 30" maple butcher block style counter top. Not even a whimper out of the router, a little warm but certainly not hot. The collet and the 1/2" whiteside spiral upcut bit were a little on the hot side but thats pretty normal. The Bosch is an excellent router also. Mine was given to me so I gave it to another future wood wrecker when I bought the PC.Steve - in Northern California
I would cast my my vote for the Dewalt 2hp with the built-in dust collection port. I tend to avoid using handheld routers because of the incredible mess (and noise) they make, but this is the only router I know of on the market that has dust integral dust collection, not some half-baked add on device. I don't own one yet, but I borrowed a friend's, and loved it. Plenty of power, easy to adjust, and my shop vac sucked up about 90% of the mess. Next on my to-buy list.
Q-sawn,
I've owned one for over a year now and find it very versatile with plenty of power. However, the it will cut out unexpectedly and you need to let go and pull the trigger again. I have not detected pattern of when this happens...maybe after 15 mins of work...and then stops after abut 15 minutes..and it is on a dedicated line with a 20amp breaker. I don't know if this is normal..but i sure don't like it..
BG,
Is it possible you're inadvertently hitting the trigger, which will disengage the trigger lock? I've done this a couple times on long cuts. I've had mine almost two years, and it hasn't cut out yet on its own. If you've had it over a year, it's out of warranty (of course), but I think I'd send it to the tool shop unless you're very comfortable tryin' to fix it yourself. Either way, it's definitely not normal.
try reading the customer reviews on amazon/tool crib- i was all set to buy a pc plunge router a couple years ago but virtually all the reviews mentioned the same three or four problems. i went with the bosch and could not be happier.
mitch
Thanks, you and Steve could be correct. I do not use the trigger lock, per se, however I am usually concentrating so hard on everything else..maintain pressure against fense, speed, dust, beer getting warm, etc. ..I don't know what Mr. Index finger is doing...gees !
I agree with the Froed. It took me a while to get used to the triger lock. At first I couldn't get it to lock at all then when I did I kept hitting the release. I've learned the tool now and don't have a problem anymore but it was frustrating to get used to.Steve - in Northern California
I'd agree with what Steve said. I've also owned the PC for about a year and it's done a great job. But I also own one of the old Milwaukee 2hp that can run all day without a problem. The only gripe with Milwaukee is no VS and no plunge.
Lar
Excellent router. I have used about fifteen and this is the best.
