I’m new to woodworking and started making small boxes for Christmas presents and have been using a 8.5″ table saw to cut 45 degree angels. The angles are not lining up right due to the amount of wood lost because of the saw width. My question is would a band saw be a better tool to use to do the 45 degree cuts with minimal wood loss?
Thanks for the help.
Steve
I don't understand your question. If the angles don't line up it's because the saw is not cutting exactly 45 degrees. It has nothing to do with the thickness of the saw blade.
Steve, Ben's right, you've got a tune-up problem here, and possibly some user-based glitches.
45* cuts for boxes and frames require a perfectly tuned saw, and require you to cut in exactly the right spot on the stock. These are 45* bevels on the ands of the stock, right??? Take some scrap stock to test the saw with. Get the blade as close as you can to 45* and then make the following test. Use a piece of stock that's at least 3/4" thick and 12" or longer. Bevel-cut it in half, roll one side over the put the two pieces together to form a right angle. Test the angle with an accurate square. Any deviation from 90 degrees means your saw needs to be tweaked. The deviation will be twice the amount your saw is "off."
Other things that can cause errors:
I've made a couple of frames that were 32" tall and 20-some-odd wide. The tiniest error will show up big-time in a frame that big. All the time you put into tuning the saw is well worth it, and if you do your final test by making a, say, 15"x15" square frame and it's perfect all the way around, you know you're home free.
Steve.
After making small jewelry boxes with mitered corners for years with no trouble,The angles started to be off ever so slightly.I discovered that the table insert was slightly below the table surface.
As I always put down pressure close to the cut,the slight depression was causing the error in the cut. An adjustment to bring the insert exactly level with the table corrected the problem.Thank you,Mr.Croney,where ever you may be.
Work safely ¬¬¬¬¬¬¬¬¬¬PAT¬¬¬¬¬¬¬¬¬¬
Edited 11/15/2004 2:29 pm ET by Pat
I've made box carcase mitres every which way ... from table saw to radial arm saw to mitre saw to hand shot with a jointer plane on a shop-built 45 degree shooting board. Up until I bought my Makita compound slider a few months ago, the only consistently perfect mitres I could get were shot by hand. Now, I go straight from the big Mak to glue-up! Just lovely, and so bloody fast!
I usually rough out my 45's on the tablesaw and then move to a shooting board and plane the joint to absolute accuracy.
Been making boxes for quite awhile and have not had problems with this method.
My second table saw is a model-makers, and is great for small boxes. Rather than fuss with miters and the arbor, I made a auxilary table set at exactly 45 degrees. My Hitchai Sliding miter saw also does a pretty decent job.Regards,
Boris"Sir, I may be drunk, but you're crazy, and I'll be sober tomorrow" -- WC Fields, "Its a Gift" 1934
Hi Dick,
What exactly is a shooting board? Is it like a straight edge? How do you use it?
Dick38
dick38,
The link below is just one example of a shooting board...
http://www.amgron.clara.net/planingpoints/rampedboard/rampindex.htm
I'll take a couple of pics this evening and post them for you.
I use a Starrett machinist's combination square (which has a 45 deg. angle) to set my blade for mitres and perpendicular. Takes a few moments longer, but eliminates a lot of problems.
A bandsaw might work, but you still have to set the angle accurately.
Q: How do you know when a politician is lying?
A: His lips are moving.
Leon
Hate your signature. I'm a politician. But I don't take myself too seriously. At a recent Rotary dinner the MC asked (I was the guest speaker) "what do you do when you run over a politician?"
I knew the answer: "Back up"
http://www.macpherson.co.nz
New Zealand | New Thinking
Mac, belike things are a tad different in NZ.Had you the experience of our most recent election, you might feel differently. Kim Philby was beginning to look like a viable candidate.Regards,Leon Jester, Roanoke VA
Leon
Nowhere in the world was immune to your recent election! Even here at the edge of the world it dominated our media for weeks.
Pity. Can you sue the Beeb for abuse?Leon Jester, Roanoke VA
Ha! CNN more like. I've got a son at Ohio State and he quite enjoyed being at the epicentre of the electoral firestorm.
Future ....
Another test that's easier to manipulate that what Jamie (Forest Girl) advised is to cross cut a 45* through a fairly thick piece of stock, flip one piece over and bring them together on a known flat surface. Such as the top of your saw. You can then verify how accurate the 45* angle is - the two pieces should meet at a hairline joint both top and bottom and all the way through.
If you're using a miter gauge to hold the work through the blade, try making a cross cut "sled" to hold the work. If this is a foreign idea, shout and I'm sure there will be any number of suggestions on how to make one.
From Beautiful Skagit Co. Wa.
Dennis
The current issue (just out) of American Woodworking has a tip on how to set up a stop block for cutting miter joints att perfect lengths.
This from a ten finger Dr. Your mention of a band saw caused me to wonder if you considered the "band sawed box" It's by far the easiest way to make small boxes.
You take a block of solid wood the size of the finished box, slice off each side, turn the center block on it's side and take a slice from the top to form the lid, cut out the inside hollow, glue the sides back on, drill and pin the lid to make hinges. There are infinite variations on this theme, with books written about it. You are then left with the center cut-out, from which you can now make smaller boxes ad infinitum.
If it were I, I would carve the recipient's name on the lid.
Tom
Steve;
Here's those photos I promised you last week. Sorry, but they say that the memory is the first thing to go and I can't remember what the second one is.
These are two different angled shooting boards, they're simple to make, just make sure of having perfect angles, and every once inawhile you'll have to true them up. One is 45 degrees and the other is 22-1/2 degrees.
The photos are pretty self explanatory, but if you have questions, holler.
Dick
Hey mate, that's a really useful contribution. Surprising how many people haven't come across shooting boards. Once you've made one that works (mine tend to be great big Heath Robinson contraptions) and got in some practice, they're a great way to make clean, sharp, perfectly fitting mitres, even in difficult stuff.
