Thank you all for help on the decision on which fence to buy. I think the unifence is a fine one. Now for the cross cut question. I was going to build a sled but am not sure if a sliding table is the way to go. The big sliders are sooo big. I’m used to walking around the saw on the left. I could try the sled first. No reason why I couldn’t have both. Maybe a small sliding table to the left and a big sled for sheet goods. I will have a big out feed and a big table right of blade. Any thoughts will be appreciated.
Build a sled. Build a number of them, each for different purposes. Add-on sliders aren't worth the money or the effort to keep them aligned. If you want a sliding tablesaw, buy a real one. I worked with a dozen sleds, bought an Exaktor, then bit the biscuit and bought a Felder. For the most part, I'm as happy as a pig in .....
Namaste,
Gary
http://gwwoodworking.com/
Gary,
Was there a problem with the Exactor??? Which one did you have???
I have one on order and honestly had heard nothing but good about them. Is there something else I should know??
TIA,
Terry
I can't recall which model I had, but I think it was their biggest one. It took up a lot of floor space, and wasn't easily removable, even with the Exaktor quick-disconnect system. I never trusted it's accuracy, after a number out-of-square 24" panels, and I forever checked and rechecked it. I hate it when I can't trust a machine. The angle device was never accurate. It took more of my time than my sleds, which I went back to before receiving my Felder.
Without enough to invest in a real slider, I'd invest in well designed, well built sleds. Simple ones for specific jobs can be repeatedly accurate for as long as you own them. More elaborate sleds, with angle adjustments are a joy to build and use, and since they ride in the table tracks, nothing can go wrong. To maintain them, just replace the runners regularly. I still have a couple that are over twenty years old! but gave most away to the guy that bought my old Unisaw. Gee, I wish I still had that saw.Namaste,
Gary
Gary,
Thanks for the reply. No way to afford a Felder or other sliding TS so I will give the sliding table a try and be carefull to double check everything.
Terry
