I’m in the market for a small dust collector. I have room only for something like the over/under, 2 bag, 1 HP Delta collector. I see that Delta recently discontinued the 50-840, replacing it with the 50-775, though the 50-840 is still available from some retailers. I will probably use a pre-separator garbage can, so the top inlet of the 840 is fine. Can anyone comment on which of these models is the better? Any other recommendations in the same size/price range?
thanks,
Scott
If you're going to use a garbage can pre-seperator, Jet has a model with it already built in. I don't see it in many catalogs, but it is out there.
