I’ve noticed a greater number of recommendations for Whiteside bits. Most of my bits are Freud, but I wanted to know if there were meaningful differences between the two so that I would switch over? It does look like the Whiteside bits are more expensive than the comparable Freud bit. Thanks
My experience is that Whiteside bits start off very sharp and stay sharp for a longer time. I have also used Freud bits and they are good but don't stay sharp as long as Whiteside. I think in the log run you will buy fewer replacement bits using Whiteside. This is my opinion and I have never read a well controlled comparison.
My experience is that Whiteside bits start off very sharp and stay sharp for a longer time. I have also used Freud bits and they are good but don't stay sharp as long as Whiteside. I think in the log run you will buy fewer replacement bits using Whiteside. This is my opinion. Have a look at this article and click on the PDF. https://www.finewoodworking.com/2007/05/01/tool-test-router-bits
I have used both and my advice is don't replace a Freud just to replace it but focus on Whiteside going forward when you need a bit. That said their are times when Whiteside won't have a particular bit I need and I will look towards Amana, Jessem, Freud and a few others but never the generic imports that flood the market and Amazon. Truth be told most hobbyists won't wear out most bits from any major manufacturer, but pros like me appreciate the little extra that a Whiteside bit offers.
Exactly what esch said.
All carbide is not created equal. Cheaper bits use cheaper carbide. Cheaper bits are painted to cover flaws and roughness. I always wonder if the balance can be off because of it.
But the biggest difference is the bearings. A couple of times I've had to grab a bit from the local big box store, and the bearing failed on the first use.
This good to know to know I just ordered some Whiteside bits.
You won't be disappointed.
My drawer is getting more and more yellow. I buy quite a few Yonico bits when I need one I know I won't use that much, or for a one off use. IMO they are just as good as Freud for half the price. And so far every bit I've ordered through Amazon gets to me within a couple days.
