Re the current video. Please can Patrick Warner explain why he preferred a climb cut with his neat jig for tenon routing? It looks to me as though a standard cut would achieve just the same result. Thanks
Hey Fencepost,
You know, I don't think there was any technical reason he made a climb cut versus a standard cut. I suspect he decided to make a climb cut because of where he was standing in relation to the workpiece; it was easier to pull the router than push it, but that's just speculation. The bottom line is, the jig works just as well with a standard cut, and the general opinion is to use a standard cut whenever possible.
Matt Berger
Fine Woodworking
Climb-cutting will also minimize tearout at the shoulders.
