Just wondering why you would mill wood wet? OK I get the idea of cracks and what not happening while wood dries out but is there any Physical reason why you should not mill dry wood??
Cheers
Cheers
I would guess the reason to mill the wood wet is that it takes too long for the log to dry out. It takes up to two years to air dry lumber that is cut 2 inches thick as it is, so if you leave the tree as a log who knows how long it would take.
And with all that moisture trapped in there for so long, it would probably be next to impossible to keep all sort of microbes, critters and other small creatures from getting in there and starting the rotting process. Just picture a log on the forest floor.
The whole milling and drying process is meant to accelerate drying to such a degree that all the small things (Jon Arno and Stanley Niemic -- sp? -- probably have the scientific names) don't have a chance to get going before it's too late.
David"The world that was not made is not won by what is done" -- Mundaka Upanishad
Good question. Maybe because a large log is likely to petrify before it dries?
I once watched the milling of timbers recovered from old warehouses and factories. These were huge beams--maybe fourteen inches wide and 20 inches deep--from slow-growth southern longleaf pine, and they'd had more than a century to air dry.
By the time the bandmill reached the center of the timbers, liquid water was visible on the surface.
You're right about the cracks, just look at a piece of dried firewood. Years ago when folks cut logs for a cabin it was desirable to store them for several years in an old barn and pack loose straw around them - all to keep cracking to a minimum.
A second reason would be to avoid the clouds of fine sawdust one would encounter in the sawmill - a hazard to the lungs and a fire danger as well. When I used to saw every once in a while a dry log would get past the scaler. A few inches into the cut and there was so much dust in the air that you couldn't see a thing, and it screamed so loudly you couldn't hear at all. (Probably didn't do the saw any good either.) We'd just drop them off the carriage and send them to the chipper
the saw mill does it wet because if you did it dry you'd have to stop every few boards to resharpen. I planed white oak both wet and dry.. wet I could plane all day.. dry I was sure to have to change blades after one timber sometimes less.
Noise too! dry sawing sets up a racket worse than wet sawing..
could you reference this for me? - - it would seem to me to be an exceptional case - log buildings (particularly 'years ago') were shelters of convenience, the most quickly erected with minimum tools using resources close at hand - having some experience, I can't imagine hewing a cured log -
thanks, DOUD
Can't remember the reference off hand - read it in an old book written in the 1940's (years ago to me) which belonged to my grandfather. Notice that I said desirable, don't know how often it was done - at least by the early settlers. Now that I think of it, I have several friends who have built log homes and they've had problems because the logs weren't dried properly.
As for hewing a cured log, if one is using pine, the most used material up in these parts, it would probably be easier.
I think the only issue is economic. You cannot store logs until dry, mill it and sell it for a profit. So you rough saw it, and either dry it and finish milling or finish milling and dry it.
Machining dry wood cannot be too hard, because we all do it.
Certainly, saw mills have equipment specialized for handling green wood, but they could have equipment for handling dry wood.
Based on some off the top of my head thinking there are many reasons for milling logs green. These include:
Did I miss anything?
The main reason is that the wood is just too hard when it is dry. Green white oak cuts like butter, when it is dry it no longer is that easy to cut. The moisture helps lubricate the saw blades.
Stephen Shepherd
It is a general misconception that water is a lubricant in relation to saws and sawblade performance.
