I at all. I begin to do a rustic furniture like Daniel Mack. I made a something whit a log tree outside. I don’t know what kind of glue it’s better for doing the job. I come from Papineauville Quebec and we have a winter. Wich one it’s gona be a better for that. Thanks at all. Budix
You need a water resistant glue...Titebond 2, plastic resin, polyurethane glue, resorcinol, epoxy, urea resin all meet the criteria.
Obviously English is your second language, (I wish I had a second language) so let me know if this does not answer your question.
Lee
Furniture Carver
Hi and thanks Lee, it's what i want to know. But for you, wich one it's the best glue. Yes i can speak two langage, but it's difficult to learn a french, we have to many verb and same if i speak french i prefer speak in english. I work for to many people who lives in the U.S states or Germany. this is for you, merci pour les informations j'ai apprécié,( thanks for your information i appreciate). Budix.
Well, my multilingual friend, the only foreign languages I know I've learned from resturaunt menus and beer bottles.
The easiest to use of the glues I listed is Titebond2. Make sure you get Titebond2 and not regular Titebond. It works just like regular yellow glue and is fine for what you're planning because it's water resistant. If you use yellow glue now and like it Titebond2 would top my list. This glue can creep so I would not use it for table tops but for glueing a chair together I would use this one first.
The next easiest to use would be polyurethane glue. I don't use this glue because of questionable results. I just don't trust this one but many do.
Plastic resin and urea are great for exterior uses. These are glues that come as powders and you mix them with water. If you need a lot of assembly time either of these powdered glues are great. I use the plastic resin a lot. Plastic resin would be my first choice for table tops or any joint that cannot permit creep.
Epoxy is great glue but it's more expensive than the others and I don't believe you get a significantly better bond however it is rigid when cured so creep will not be an issue and you'll have a nice, long open time.
So, in descending order my choices would be... Titebond2, Plastic Resin, Urea Resin, Epoxy, then coming in at a distant sixth would be Polyurethane.
Lee
Lee Grindinger
Furniture Carver
