I’ve built a couple of quilt racks out of Cherry for a wedding present. I put one coat of Danish Oil on the racks, and it looks really nice.
My question: Will the Danish Oil eventually seep out of the wood and stain the quilt? Do I need to apply a poly or WOP to create a barrier between the quilt and wood?
yieldmap
I sure would.
PlaneWood
After waiting for the oil to thoroughly cure, apply a few coats of shellac. It makes a terrific sealer coat and can be applied over just about anything. Wiping on the shellac will work just fine, and there'll be no pesky brush marks, drips, or other such imperfections to contend with.
BTW, after you've given the oil a few weeks to cure, you may find that the luster has diminshed somewhat; I generally sand in Liberon Finishing Oil for my oil finishes (220, 320, 400, up through 500 & 600 in some instances) followed by a high-quality wax.
Good luck,
-Jazzdogg-
yeildmap
If you use light coats and let it cure properly, I would guess no. But that is only a guess as I have never run a test with a quilt draped over a Danish oil finish.
Therefore I would tend to agree with Planewood and play it safe. Better safe than sorry.
Regards...
sarge..jt
What "Danish Oil" did you use? Many different types of finishes are called "Danish Oil" for marketing reasons.
Most danish oil is an oil/varnish mixture of boiled linseed oil, varnish and mineral spirits. Once it has fully dried (4-7 days), it will not bleed back. The varnish in the mixture seals the pores and the finish.
If you want additional protection, wipe on a couple of coats of a wiping varnish. Thin your varnish 50/50 with mineral spirits and wipe it on using non-embossed paper towels.
The thing to be careful of with any oil base finish is the odor that can permeate cloth items. It's mostly a problem inside cabinets and drawers but quilts left draped over an oil finish item may pick up some of the odor. Might be best to overcoat the "danish oil" with shellac or a waterborne clear finish.
Watco Danish Oil.
I'm not as worried about odor, but more stains. The quilt rack is a "Pinch rack", which holds the quilt between two boards with pressure from 4 screw knobs.
So, the quilt will always be under pressure between two boards. That's why I'm concerned about the staining.
I might try either a WOP or shellac, just a couple of coats. I've used the WOP with the Danish Oil before and it doesn't change the color much. I've been happy with it.
yieldmap
If you're not facing a short deadline, why not try it with your wood and your choice of finish and see what happens?
I would not use an oil finish in this situation, unless you topcoat with shellac. A regular wiping varnish would be my choice. While Watco has varnish in it, it is still mostly linseed oil and could very well bleed back.
No reason to take a chance.
I already had the Danish Oil on when I posted. However, I did take your advice with the shellac, two coats. What a beautiful finish. I'd never used much shellac before.
Can you buff the shellac out to make a nice shine? I've heard of using the 3M abrasive cloth (plastic steel wool) instead of steel wool. Have you ever used that?
thanks,
yieldmap
Nah, leave it alone if it looks good. Don't be afraid to be done with the project. Hang some quilts on it and enjoy.
