In issue 192 of FWW are the plans for the Adirondack chair. I’m not concerned so much about the weight of the finished product but oak is easy to work with and seems to withstand the outdoor elements for a long time. (Besides, I have quite a bit of it left over from other projects!) If any readers can suggest what oak to use and what to finish it with, I’d sure appreciate the advice.
If you use oak, make sure it's white oak and not red. It stands up to the weather whereas red doesn't. I've made some outdoor furniture with white oak and it looks good left natural, at least to me anyway.
The main thing I've found with outdoor furniture is to protect the feet/legs from wicking moisture from the ground.
ONe of the best ways to protect the feet from moisture: sit the piece upside down and level; use masking tape to create a dam around the end of the leg; pour in Bondo or similar epoxy-type compound to about 1/8 to 1/4 inch thick; when dry, remove the tape and sand the bottom flat. This also sames the wooden leg from abrasion. And you seldom even notice that the foot has this little protective coating on it.
Jim Bell
That's a great suggestion. I've painted the very ends of my outdoor furniture feet with slow setting epoxy and that seems to work fairly well also.
On all my out door furniture I install those plastic buttons with a nail molded in so that all you have to do is nail the button in to the end of the legs. thry hold the legs off the ground by about 1/4". Also easy to slide around on the deck or cement.
