I am building an air filter for my woodshop using a salvaged whole house furnace squirrel cage blower. The blower has 7 wires coming out of the GE motor. 2 brown wires go to a Dielektrol Capacitor. The other 5 (red, blue, yellow, black, white) go to a white strip plug (4, 3, 2, 1, C).
I want to wire the blower thru a junction box on the side of the filter box, with a switch, to a 110v outlet. I would appreciate any guidance on this electrical project. Would you know if the blower speed is changeable?
I’ve put off dust control in my shop/garage far too long and now I have left over plywood laying around so it is time to build it!
Forrest
this is not ####GE connection diagram, but find ####four pos switch,and hook up the wires you have like this, and swap the colored leads if this is not the right match
white- common---neu.
red---low
blu- med
yel-m. high
black ,high
I'm a little unsure of your terminology. Can you explain ####?
that ....####...... happens every once in awhile, we tried to duplicate the circumstances at BT when the last "new " regristration took place, as it seemed to begin right about that time..........it seems to be any combinaton of the letter "a" and just about everything elseapparently the Prospero software is very sensitive about the letter known as "a"if you preview your post the censored word can be re-typed and the...... ####..... doesn't show up again
Edited 1/7/2006 11:49 am by maddog3
as well a swell, as whole, a hole, a snot
Did you remove this fan from the furnace? If so, there is a diagram in all of them and it will show the wiring to the motor.
Thanks Maddog, Tinkerer and Highfish for the input. Looks like I should remove the motor from the housing and find the wiring diagram. Yes, I did remove it from a furnace at the HVAC shop I scrounged it from. Do you suppose the wiring diagram will have the RPM or the voltage for each wire chosen? The question becomes can I get 1000cfm out of the blower.
the voltage must connect to only one lead at a time..... do you have any data on, or inside the fan housing...like a data plate or sticker..sometimes the connecting diagrams are on the flip side of the wiring cover..if there is one!!! model number ? what are the dims. of the motor and shaft ??the speed you want is probably one of those leads .... pick the speed you want ant tape the ends of the remaining wires
I would guess that your top speed is something around 1100rpm...how that relates to cfm, I just simply do not know
sent the last one to me by mistake........I hate Sundays
Are you sure you want 1000 CFM from it when it's being used to filter the air? That's going to cause a lot or turbulence and kick up whatever dust is in the airflow. OTOH, if you set it up right, you'll never need to dust. Just turn it on 1/2 hour before going out there and with a really efficient filter, the air should be pristene.
Forrest,
Do an advance search for "air scrubber" under my Knots name - JackieChan. I've posted complete plans and wiring diagrams for the air scrubbers that I've built and use in my shop.
If you have any questions, please feel free to ask!
Dan Kornfeld, Owner/President - Odyssey Wood Design, Inc.
Well, I'm glad to find out the GE motor is 115vac and 1/2 hp. The label was under the clamp. The wiring is laid out thus; red-lo, blue-med, yellow-med hi, black-hi. I'll bench test the various speeds to decide which to go with first. I can always rewire if I'm not satisfied.
JackieChan, your article and drawings got me started on the shop build. Your wiring diagram only shows 2 black leads from the motor so I had to sort that out. Salvaging the blower from a HVAC was a snap. They were glad to accomodate. Now I have a new service provider for my furnace.
Thanks to all for the helping hands.
Excellent just remember to insulate any unused motor leads,and you're good to go
