A friend of mine would like to build an enclosure for a radiator that is in his bathroom. He is planning on making a case that has three sides, is attached to the wall on the fourth side, and is open on top with a piece of metal (with some grid pattern in it) on top to let the heat out. Even if we use dried lumber (red or white oak – 1″) I am concerned that the heat is going to cause the wood to crack in short order. Is there another type of wood we should choose or a tip/technique to avoid the splitting?
Tom
Actually, radiator enclosures are pretty common. Design for plenty of wood movement by using floating panels with lots of "slop" in the slots. Don't forget to leave gaps to allow cool air to enter at the bottom. However, most of these have screens for front panels as well as the top. Remember, a radiator is supposed to radiate. What you are describing is convection heating (heat rising out of the top). If you subtract the radiation aspect, you'll lose a lot of efficiency from the unit.
Mike Hennessy
Pittsburgh, PA
The heat alone doesn't cause wood to crack. The cracks come when the wood shrinks from the drying caused by the heat and the design of the piece doesn't allow for the shrinkage.
Just follow good design practice, careful choice of lumber, floating panels, or tongue and groove construction for instance, with allowance for the larger than normal wood movement and the piece should hold up just fine.
Thanks for the info. We will add a screen into the front panal to maximize heating potential. So a glued tongue and groove design to hold everything together would allow for enough expansion that there shouldn't be problems with cracking? Obviously no screws or nails as that would prevent movement. THanks again. Tom
T&G is normally nailed along only one edge allowing the individual boards to expand and contract, the T&G joint between the boards keeping them aligned but permitting movement. If your reference to "glued tongue and groove" means that you are planning to glue all the boards together down the length of each T&G edge, then the joints won't be able to open and you will have problems with cracking.
John W.
